Going From Stock 50 OFFSET to 60 OFFSET - Negative Affects?
Old Nov 2, 2006 | 07:40 AM
Lucky-R's Avatar
Default Going From Stock 50 OFFSET to 60 OFFSET - Negative Affects?
im looking at a set of wheels that are pretty hard to come by, only thing is the offset is 60 and the itr is stock 50 offset. i realize i will in all likelihood need to use spacers to clear the brakes, but is this 10 mm difference going to make a BIG difference that might be considered not worth the purchase?
my main concerns are clearance of the fenders, how noticeable will they stick out and more importantly, will i feel a negative change in performance or "feel" from extending out 10 mm more than usual? im also guessing that i will need to find longer studs all around...
Old Nov 2, 2006 | 09:15 AM
FalkenSiR's Avatar
Default Re: Going From Stock 50 OFFSET to 60 OFFSET - Negative Affects? (Lucky-R)
The wheel/tire will tuck in 10mm towards the inside of the wheel well. I don't know too much about spacers, but running a 1cm spacer sounds kinda scary, that's about .5" BTW. You will probably need it tho, if you really want to keep those wheels and run an oem-spec offset.
High offset = tuck in
Low offset = stick out
Old Nov 2, 2006 | 05:01 PM
tr1plesix.'s Avatar
Are you thinking about buying those 16X7 +60MM M7s?
You can run a 10MM spacer without extended studs.
Old Nov 3, 2006 | 02:07 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (tr1plesix.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tr1plesix. &raquo;</TD></TR><TR><TD CLASS="quote">You can run a 10MM spacer without extended studs.</TD></TR></TABLE>
Make sure you have at least six full turns on the lug nuts. (Some people recommend at least seven.)
Old Nov 3, 2006 | 09:13 PM
vtecsi00's Avatar
Default Re: (nsxtasy)
seven full turns would be ideal
Type-ARR
Feb 18, 2011 05:30 AM
cmdr430
Mar 20, 2008 07:18 PM
AlienKrOZ
Jun 5, 2006 04:40 PM
GreenD
Feb 16, 2004 09:57 PM
Drumwurks
Nov 26, 2002 03:26 PM
