Fender to offset question on tires size.
I was wondering on few things....I Currently have 205/45/16 and it clears the fenders easily front and rear with a 1.5 inch drop. I have a offset of +38(16x7). I was wondering if anyone uses a 215/45 or 225/45 on a 16 with same settings? i know I would have to roll the rear fenders.
But my concerns are....would it rubb when turning? And, should I stick with the same size(205/45) or should I go 215/45?
I have a 99 Civic Coupe
I have the choices of these tires.
BS RE750(205/45)
YH AVS ES100(205/45 or 225/45)
Toyo Proxes4(205/45 or 215/45)
I'm leaning towards in the order from top to bottom.
BS RE750(205/45)
Yeah you're really going to just have to test fit and find out. The odds of someone having the same setup will be unlikely and every car will have a different stance regardless.
But when you're increasing the width, your sidewall is also going to increase. Right now you have a 92.25mm sidewall height, from bead to top of tread. If you increased to a 215 you're going to have a 96.75mm and a 225 would net a 101.25mm difference. If you can somehow measure it, check to see if you can spare a extra 4mm (I'm sure you can) or even a spare 9mm. That would be the only sure fire way of knowing. But also, unless you've got some super-stiff race springs, your car will roll and that gap in between will decrease, possibly resulting in a rubbing situation.
But if it's working fine, why not just stay with what works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joebroni »</TD></TR><TR><TD CLASS="quote">Yeah you're really going to just have to test fit and find out. The odds of someone having the same setup will be unlikely and every car will have a different stance regardless.
But if it's working fine, why not just stay with what works.</TD></TR></TABLE>
Yeah, I went today and sticked with the same size of 205/45/16 YH AVS ES100. The 215 or 225 will work only if it's a "40 series." And also minor fender roll. But it fits nicely without any concern.
But bad news. I found out 1 of my rim is badly bent. This sux.
Now I have to go find the same size rims(a set) and offset to replace them.
Any recomenations? I was thinking the FN01R-C(black polish) or something.
