Does age do anything to tires?
Old Dec 21, 2006 | 06:22 AM
GsDAteg's Avatar
Default Does age do anything to tires?
I have a set of studded snow tires I need to put on but I havent used these tires for like 6-7 years. I only used them for a couple months so they are practically brand new, just hella old. So does anything negative happen to a tire that sits for so long or should I be good to go?
Old Dec 21, 2006 | 07:16 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Does age do anything to tires? (GsDAteg)
http://www.tirerack.com/tires/...d=138
Old Dec 21, 2006 | 07:27 AM
GsDAteg's Avatar
Default Re: Does age do anything to tires? (nsxtasy)
According to that my tires are right on the verge of being too old, unless I plan on doing some autobahn driving then they say they are illegal.
But it really only talks about the weather conditions and stuff affecting them. These tires have been in my grage the enitre time so the elements should not be a problem. They only got used for a couple months and sat in the garage the rest of the time. So besides getting cold in the winter these tires are not exposed to any kind of weather. It does say that infrequent use and improper storing can accelerate the proccess. Does how I kept them count as improper storing?
I'm thinking I might put them on for this winter and just go with some new ones for next winter. What would you guys do if you were in my situation?
Old Dec 21, 2006 | 07:36 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsDAteg &raquo;</TD></TR><TR><TD CLASS="quote">Does how I kept them count as improper storing?</TD></TR></TABLE>
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsDAteg &raquo;</TD></TR><TR><TD CLASS="quote">What would you guys do if you were in my situation? </TD></TR></TABLE>
I would inspect them closely, and if they don't show any evidence of cracking or other problems, I would continue using them for another 2-3 winters...
Old Dec 21, 2006 | 08:02 AM
GsDAteg's Avatar
Just went over them and could not find a single crack or anything odd looking. I'm going to go ahead and throw them on for the time being and try to get new ones for next year. Thanks for the help.
Modified by GsDAteg at 1:02 PM 12/21/2006
Old Dec 22, 2006 | 05:52 AM
SHPrelude00's Avatar
Default Re: (GsDAteg)
ill put it to ya like this... shelf life on a tire is 3 years... when we have a tire here in our store or in stock it must be disposed of after 3 years of shelf life... so there must be a reason... i would just say be careful when you ride on them...
Old Dec 22, 2006 | 06:59 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (SHPrelude00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHPrelude00 &raquo;</TD></TR><TR><TD CLASS="quote">shelf life on a tire is 3 years...</TD></TR></TABLE>
...which makes sense, according to the Tire Rack's write-up, if you assume that the consumer is going to use any tire you sell for 3-7 years after you sell it.
Old Dec 22, 2006 | 07:20 AM
Doespike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">http://www.tirerack.com/tires/...d=138</TD></TR></TABLE>
Here's an interesting if not silly question...is there anyway to "preserve" brand new unmounted tires? This question popped into my head when I heard the Integra Type R OEM tires were being discontinued and cleared out. I know there are a number of tires that are worthy replacements of the Bridgestone RE010 but to a collector 20 years from now, having a set of the OEMs on his/her pristine ITR would be neat.
Old Dec 22, 2006 | 07:29 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Does age do anything to tires? (Doespike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doespike &raquo;</TD></TR><TR><TD CLASS="quote">is there anyway to "preserve" brand new unmounted tires?</TD></TR></TABLE>
http://www.tirerack.com/tires/...id=37
Old Dec 22, 2006 | 07:47 AM
Doespike's Avatar
Yeah, I should really browse Tirerack's articles more often. :embarrassed:
Old Dec 22, 2006 | 04:01 PM
vtecsi00's Avatar
tire shelf life is 5 years.. tires that have not been sold by that time are writtten out of stock and recycled....tires aredesigned only to last between 5-7 years now. tires that get that old either have ozone cracks, rubber is hard (stiff), and crack also in the tread as well..which means that they are garbage
Old Dec 23, 2006 | 09:21 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Does age do anything to tires? (vtecsi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">tire shelf life is 5 years.. tires that have not been sold by that time are writtten out of stock and recycled....tires aredesigned only to last between 5-7 years now. tires that get that old either have ozone cracks, rubber is hard (stiff), and crack also in the tread as well..which means that they are garbage</TD></TR></TABLE>
That depends. They don't necessarily have those problems, if they've been indoors and properly stored for much of that time, as many winter tires are. Inspect them. If they have significant cracking, toss 'em. If they don't, you can keep using them. As the Tire Rack notes, tires may be used for up to 6-10 years.
Old Dec 23, 2006 | 10:09 AM
vtecsi00's Avatar
that maybe what the rack tells you. but from michelin and other ctire companies shelf life is five years and that's it
Old Dec 23, 2006 | 10:53 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">that maybe what the rack tells you. but from michelin and other ctire companies shelf life is five years and that's it </TD></TR></TABLE>
Do you mean shelf life as in, the length of time they are stocked at the tire dealer before they are sold to the consumer? Or the length of time from the date of manufacture until they are so old they should be disposed of? Those are two different things, and as you can already see in this post, the same term could be used to refer to either one...
Old Dec 23, 2006 | 11:11 AM
vtecsi00's Avatar
life as when the tire was manufactured from the factory according to the dot number's on the tire... and that goes for shelf life as well. every tire comes with a serial number showing when the tire was produced as you no nsxtasy. when a tire is on the shelf for five years from date of being made the tire is garbage. from date of made and tire on car more than 7 yrs time to think of replacing your tires because the material of the tire is most likely going to start to harden up, have weather cracks or stress cracks on the sidewall or in the tread
Old Dec 23, 2006 | 01:11 PM
nsxtasy's Avatar
H-T Order of Merit
As you know, the Tire Rack and the British Rubber Manufacturer's Association both disagree with you and say that tires can last anywhere from six to ten years. Especially with winter tires that are not exposed to the elements for nine months a year, assuming that no cracking or other problems are visible, I think ten years is a reasonable assumption.
Old Dec 23, 2006 | 03:50 PM
old man neri's Avatar
I think what vtec is saying is that if a tire is not sold within 5 years it should be disposed of. nsxtasy is saying a tire will last for 6-10. The two are different but mean the same thing.
Someone who buys a tire will use it for 3yrs, maybe more, maybe less. Now if that person buys a tire that is already 5 years old, or older, he could quickly find himself exceeding that '5-7 year lifespan' tirerack quotes. Thus the reason why stores will dispose of their 5yr old tires. (Who knows what kind of environment those tires were stored in during those 5 years)
Shelf life is the time span from date of manufacturing to the date it is sold/first used.
Life span is the time span from date of manufacturing to the date it must no longer be used. (in this case)
Does this babble help anyone?
Old Dec 23, 2006 | 07:57 PM
vtecsi00's Avatar
Default Re: Does age do anything to tires? (old man neri)
that's what i was trying to say but obviously wasn't saying the right way for nsxtasy to understand.. thanks old man neri
Old Dec 23, 2006 | 08:47 PM
nsxtasy's Avatar
H-T Order of Merit
Yes, that's why I had asked what you meant...
Happy holidays to everyone, and may all your tires roll you to happiness in the new year!
Old Dec 24, 2006 | 01:45 AM
vtecsi00's Avatar
my bad a long day....
Have a Merry Christmas everyone
Old Dec 24, 2006 | 07:37 AM
PSU's Avatar
PSU
formerly DxHatchback
interesting thread and interesting read on the two tire rack articles posted
thanks
Old Dec 24, 2006 | 07:56 AM
Boosted B6teen's Avatar
Default Re: Does age do anything to tires? (DxHatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxHatchback &raquo;</TD></TR><TR><TD CLASS="quote">interesting thread and interesting read on the two tire rack articles posted
thanks </TD></TR></TABLE>
X2
Uncle Ben's
Nov 22, 2009 09:37 AM
eoris__ej1
Apr 29, 2009 04:03 AM
Yellow Dragon
Nov 18, 2008 08:51 AM
AlienKrOZ
Dec 14, 2006 03:37 PM
sshotrr
Honda S2000
Oct 28, 2001 07:16 AM
