bbs mesh basketweave
BBS RMs are 2-piece 15x6.5, came on 1990-1992 GTI 16v
there are others like BBS RAs which are 1-piece and came on Jetta GLIs. BBS RS 001s are 4x100 3-piece but I don't know what they came on, not any stock VW.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dualweberVW »</TD></TR><TR><TD CLASS="quote">
and yes, lots of old bimmers, like a 318is, 14" 4x100</TD></TR></TABLE>
Here are some on a VW that will fit a honda (only difference is the bore size, it is too big by 1mm), they came off a bimmer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dualweberVW »</TD></TR><TR><TD CLASS="quote">lots of old bimmers, like a 318is, 14" 4x100</TD></TR></TABLE>
I have a set from my '91 318is. Authentic BBS 14x6.5" wheels, 35mm offset, silver finish. Make offer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dualweberVW »</TD></TR><TR><TD CLASS="quote">^^^those don't look like bbs, more like an old MSW wheel.
dude whata you know about msw and bbs wheels
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pzn801 »</TD></TR><TR><TD CLASS="quote">i like those on that white vw....bump back up!!!</TD></TR></TABLE>
Most people don't like them on a civic for some reason. I love em and that's all that matters to me.
The problem you will have with using rims off BMWs and probably most BBSs is the bore size for one (I think most of them are 57.1mm and your civic is 56.1mm), not the end of the world. The bigger problem is the offset, the rims you see there are +13 offset. Not the easiest to get to work.
Here is a pic to demonstrate the offset.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efvader »</TD></TR><TR><TD CLASS="quote">
busted
</TD></TR></TABLE>busted
1991 and 1992 Corrado G60's came with BBS's and i do believe they were a bit different than the SLC/VR6 RM's, i believe the G60's had a bit of a lip to them and they rounded back in at the ends... i could be wrong it's been years since i've seen a G60 on stock BBS's...
if you're gonna try a junk yard in hopes of basket weaves look for Rabbits... i've seen alot more valueble MK1 rabbit parts be pulled from a junk yard than that... for example full BBS and Zender kits i've seen both been pulled from a junk yard...
oh yeh porsche 928's also had weaves... good luck with the bolt pattern though...
Nice rims
Nice rims
