Thermal arc users - smaller torch?
Old Jun 9, 2007 | 07:33 PM
CoreyR's Avatar
Default Thermal arc users - smaller torch?
my torch is getting a bit beat and id prefer something thats not as bulky as the stock #17 torch. i went to the local welding supply place and they couldnt really help me and/or didnt know what will work (probably because they push lincoln crap). any places that sell something a bit smaller that works with the thermal arc TSW185 thats not watercooled of course?
thanks
Old Jun 9, 2007 | 09:39 PM
k24em2's Avatar
Default Re: Thermal arc users - smaller torch? (CoreyR)
GTAW torches are fairly interchangeable, I think a #9 is a smaller air cooled that you could pick up.
Old Jun 9, 2007 | 09:44 PM
CoreyR's Avatar
Default Re: Thermal arc users - smaller torch? (k24em2)
thermal arc has a different connection at the welder. torches that fit miller/lincoln units wont fit the TA.
Old Jun 10, 2007 | 05:03 AM
117's Avatar
117
I ordered a CK9F flex head torch from http://www.tigdepot.com for my TA185. It works quite nicely, but unfortunately tigdepot appearas to be out of business.
Old Jun 10, 2007 | 12:16 PM
CoreyR's Avatar
Default Re: (117)
what brand is the torch? how do you like it?
Old Jun 10, 2007 | 12:27 PM
Lamchop0000's Avatar
Default Re: (CoreyR)
i got a weldtec WT20 torch. which requires a water cooler to operate.
small, light, and no more hot torch
Old Jun 10, 2007 | 12:43 PM
CoreyR's Avatar
Default Re: (Lamchop0000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lamchop0000 &raquo;</TD></TR><TR><TD CLASS="quote">i got a weldtec WT20 torch. which requires a water cooler to operate.
small, light, and no more hot torch</TD></TR></TABLE>
haha not trying to drop coin on a water cooler
Old Jun 10, 2007 | 01:22 PM
1fastVX's Avatar
Default Re: (117)
I think Tig Depot just changed there website address.
http://www.tigdepot.net/
John
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">I ordered a CK9F flex head torch from http://www.tigdepot.com for my TA185. It works quite nicely, but unfortunately tigdepot appearas to be out of business.</TD></TR></TABLE>
Old Jun 10, 2007 | 02:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">
haha not trying to drop coin on a water cooler </TD></TR></TABLE>
what amps are you welding at? the 9 torch is equavalant to my 20 but air cooled version. for air cooled i wouldnt go smaller then a 9.
even tho its rated at 125amps. i image it would be pretty toasty after a few minutes of use. the CK 17 torch that the TA185 comes with is rated at 150 and that thign was scorching especially when welding aluminum.
and for connecting it to a TA185 you will need the type that has side hose, not flow thru like lincoln and miller uses.
...you can use flow thru style but you have to buy a dinse adaptor. like this one.
http://www.weldingdirect.com/flowconwitsi.html
Old Jun 10, 2007 | 03:04 PM
CSaddict's Avatar
Corey the welding supply up here has all the CK and Weldcraft stuff and carries the tiny stuff. You just have to make sure you get the split style hose connection.
Old Jun 11, 2007 | 12:26 AM
CoreyR's Avatar
Default Re: (CSaddict)
mariam graves?
might have to check it out. you know how big and stupid the stock torch is and why iw ant to get rid of it.
Old Jun 11, 2007 | 12:30 AM
CoreyR's Avatar
http://www.weldingdirect.com/flowconwitsi.html</TD></TR></TABLE>
yeah i only time i usually go over 125 on steel is head flange welds. and the torch def. gets hot hot hot. aluminum is even worse. id rather take more breaks for cool down and use a smaller more confortable torch. thanks for the link, if i cant find a bolt up torch ill pick that up.
Old Jun 11, 2007 | 02:55 AM
117's Avatar
117
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">what brand is the torch? how do you like it?</TD></TR></TABLE>
CK is the brand. It's a CK9F flex head. I like it alot, but on higher amperage stuff, it does tend to get quite warm. IIRC, all you have to do is the get the split connection, where one is the dinse (sp?) power connector and the other is the gas connector. On the Millers and Lincolns I have seen, they have a gas through dinse, so it's a single power and gas connection, where the TA185 is split.
Old Jun 11, 2007 | 02:57 AM
117's Avatar
117
Default Re: (1fastVX)
That's the one! Thanks! It didn't come up when I searched for some reason. The new web site doesn't have as many items or as much detail as the old one. I wonder why they changed...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fastVX &raquo;</TD></TR><TR><TD CLASS="quote">I think Tig Depot just changed there website address.
sony224422
Dec 4, 2007 01:41 PM
zc911
Honda Motorcycles
May 19, 2007 07:36 AM
ninja 6
Honda Motorcycles
10
Feb 8, 2007 03:48 PM
SiMateoAko
Honda Fit
12
Sep 24, 2006 05:25 PM
JDMGSRCRX
Honda Motorcycles
Sep 3, 2004 11:34 AM
