Question regarding Rollcage Welds
Old Jan 17, 2008 | 09:29 PM
siblues's Avatar
Default Question regarding Rollcage Welds
I was wondering if you guys wouldnt mind answering a few questions for me.I plan on running my car in nhra and I have a 8 point cage welded in the car.My question is I plan on having the car repainted real soon inside and out and the welds around the base plates are kinda rough.The welds have good penetration and they seem strong but they are a bit rough to look at.I was wondering if it is ok to give them another pass or are they allowed to be ground down at all after the second pass or should I just smoth it out around the base plates with seam sealer and repaint?Thanks any help is greatly appreciated
Old Jan 18, 2008 | 05:38 AM
Pyrorocketeer's Avatar
Default Re: Question regarding Rollcage Welds (siblues)
If you grind, I'm pretty sure you have to re-weld. Not allowed to grind a finished weld smooth.
Old Jan 18, 2008 | 08:07 AM
RCautoworks's Avatar
Default Re: Question regarding Rollcage Welds (Pyrorocketeer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pyrorocketeer &raquo;</TD></TR><TR><TD CLASS="quote">If you grind, I'm pretty sure you have to re-weld. Not allowed to grind a finished weld smooth. </TD></TR></TABLE>
You are correct, If there that bad I would go over them, just think about safety.
Old Jan 18, 2008 | 09:35 AM
Goullish's Avatar
Default Re: Question regarding Rollcage Welds (RCautoworks)
"They seem strong"? I've always used one rule when it comes to eyeballing welds - Bad looking welds have a very high chance of being bad. Good looking welds look good, but still have that chance of being bad.
Old Jan 18, 2008 | 09:55 AM
siblues's Avatar
Default Re: Question regarding Rollcage Welds (Goullish)
Well the welds arent really bad I just really want the results to be as close to perfect as possible.I have no way of telling how strong the welds are except for eyballing them and they look good.The welds are in no way bad they just arent up to my specs.I will stay away from grinding them but will using seam sealer over the base plate welds be ok with the sanctioning body?
Old Jan 18, 2008 | 01:08 PM
Goullish's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote"> will using seam sealer over the Wbase plate welds be ok with the sanctioning body?</TD></TR></TABLE>
I'm gonna go with a no.
Old Jan 18, 2008 | 05:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote">I will stay away from grinding them but will using seam sealer over the base plate welds be ok with the sanctioning body?</TD></TR></TABLE>
I have actually heard some people doing this to cover up hard to reach welds. Is it ok, nope not at all. If your worried that much about it passing, the weld can't be that good. Although I have seen some bad welds bad.
Old Jan 18, 2008 | 06:48 PM
siblues's Avatar
Let me clear this up sorry for not describing it properly the welds are fine.I am not trying to cover anything up really.I am just trying to get the welds around the base plates to be as smooth as possible to get the interior of the car painted and so that it looks really smooth.
Old Jan 19, 2008 | 07:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote">Let me clear this up sorry for not describing it properly the welds are fine.I am not trying to cover anything up really.I am just trying to get the welds around the base plates to be as smooth as possible to get the interior of the car painted and so that it looks really smooth.</TD></TR></TABLE>
Its still not ok to do, unless the cage already pass tech. If you are trying to do all this before tech its against the rules.
Old Jan 19, 2008 | 01:39 PM
siblues's Avatar
Thank you thats the answer I was looking for
silentdaredevil2
Oct 8, 2006 09:07 AM
dragaholic
Aug 27, 2006 08:17 AM
00gsrBrynn
Apr 10, 2005 04:13 PM
s1ngle
May 10, 2004 09:02 AM
RoAnSa
Oct 16, 2003 12:03 AM
