WOW that is sick
sick that is all i can say
thats a dope ass setup. haven't seen anything like this in a while.
Re: (BOOSTEd2)
VERY nice work!! https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
my friend had a twin turbo setup on a mustang with kinda similar turbo locations. he was having a problem with oil return from his turbos, because the line wasn't sloped enough to get the oil back to the oil pan. since the oil had no where to go, it would leak past the seals and smoke. i think his turbos were mounted a little lower though, but it might be something to be aware of. |
Re: (ARC Magic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARC Magic »</TD></TR><TR><TD CLASS="quote">VERY nice work!! https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
my friend had a twin turbo setup on a mustang with kinda similar turbo locations. he was having a problem with oil return from his turbos, because the line wasn't sloped enough to get the oil back to the oil pan. since the oil had no where to go, it would leak past the seals and smoke. i think his turbos were mounted a little lower though, but it might be something to be aware of. </TD></TR></TABLE> Thanks. I won't be relying much on gravity for the oil return since i'll be using a scavenge pump. |
Re: (R@mon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R@mon »</TD></TR><TR><TD CLASS="quote">
Thanks. I won't be relying much on gravity for the oil return since i'll be using a scavenge pump.</TD></TR></TABLE> nice.. glad you got that covered!! https://honda-tech.com/forums/images/smilies/emthup.gif keep up the good work!! |
badass! keep us updated!
Re: (iv)
thats the last car i would ever want to see in my rear veiw. https://honda-tech.com/forums/images...s/emsmilep.gif
Re: Little project of mine (R@mon)
words can not express............ HOW BAD A$$ THIS CAR IS !!!!!!!!!!!!!!!!!!!!!!!!!!! https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images...es/emsmile.gif
Re: (SwappedTURBOegg)
damn dude thats some sick ass shit! https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Little project of mine (714phil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 714phil »</TD></TR><TR><TD CLASS="quote">have you ever seen factory VQ rods... on weeeed??</TD></TR></TABLE>
rofl. That was awesome. |
Oh, also.. can you give me some more info on how you're planning on running the radiator in the back of the car? Also, what are you planning on doing for filters (will you even run filters?)?
Sorry if you've already explained either of these. |
Re: (ZzZCivicZzZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZzZCivicZzZ »</TD></TR><TR><TD CLASS="quote">Oh, also.. can you give me some more info on how you're planning on running the radiator in the back of the car? Also, what are you planning on doing for filters (will you even run filters?)?
Sorry if you've already explained either of these.</TD></TR></TABLE> I'll be cutting out the spare tire well and mounting the rad back there. The fans will be mounted on the bottom side drawing air from inside the car and pulling it out. I'll have rigidly mounted aluminum tubing mounted under the car that will transfer the coolant from front to back with -16 bungs on the ends. Then, i'll have some -16 hoses connecting the rad to the tubing and to the motor. I'll also have a small 30gpm water pump inline helping to pump the coolant to the motor. Not sure about the filters. I'll figure that out when it's time. lol |
Sounds like you've got it down. https://honda-tech.com/forums/images/smilies/emthup.gif Best of luck. We're lovin' your project over at HighAltitudeImports.com!
Re: (ZzZCivicZzZ)
Thanks guys.
WOW! amazing, when do you expect to be done?
Re: (fventura03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 »</TD></TR><TR><TD CLASS="quote">WOW! amazing, when do you expect to be done?</TD></TR></TABLE>
Never...lol I really don't know. Right now there's a money issue and i'm not going to cut corners to finish it quicker so i really can't say. |
Sick!!!
Re: Little project of mine (B18Flip)
subscribed, for ideas when I swap a VQ into my 510. Won't be boosting it though.
i'm subscribing for this one... NICE.
Wow - this is a really amazing build! Exactly the reason I drift into Welding/Fab every now and again ! :D
Re: (R@mon)
I rather build my own parts whenever possible. It doesn't matter if they don't workout that great, i usually end up making something new within a couple of months anyways. https://honda-tech.com/forums/images...es/emsmile.gif </TD></TR></TABLE> If I could fit more into my sig, I would totally add this. Amen to that bro. https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (Boostwerks.com)
Damn nice work Bro! im wonting to know the flow test on that intake manifold. cant wait to see this finished. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (ZzZCivicZzZ)
looks good man, good luck... https://honda-tech.com/forums/images/smilies/emthup.gif
