Hardest way to put an engine in...
Old Jan 13, 2005 | 01:35 AM
ExploitedRacing-HR's Avatar
Default Hardest way to put an engine in...
The way i did it... by hand.
That sucked.
Old Jan 13, 2005 | 02:19 AM
boosted-delslow's Avatar
Default Re: Hardest way to put an engine in... (ExploitedRacing)
Me and my freind did that once. But it was a long block.
Old Jan 13, 2005 | 03:02 AM
Finland's Avatar
wow...you guys are nuts...
Old Jan 13, 2005 | 05:44 AM
IHaveTurbos's Avatar
Default Re: (ForceFedDetroit)
And a 4G63 Block isn't the lightest block either.
Old Jan 13, 2005 | 05:54 AM
CompressionFed's Avatar
Default Re: (Speed-Factor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed-Factor &raquo;</TD></TR><TR><TD CLASS="quote">And a 4G63 Block isn't the lightest block either.</TD></TR></TABLE>
You can say that again! Those bastards are heavy!
Old Jan 13, 2005 | 06:33 AM
david@didrace.com's Avatar
Engine hoists are nice.
Old Jan 13, 2005 | 10:45 AM
RCautoworks's Avatar
Default Re: Hardest way to put an engine in... (backpurge)
Why ?
Old Jan 13, 2005 | 11:24 AM
ohboy95c's Avatar
Default Re: Hardest way to put an engine in... (90blackcrx)
was that car on cynder blocks. if you hand a lift you could drop the motor right to the floor, undo the mounts and raise the car. the engine stays right on the ground. This can also be done with a set of jacks in the front with the front tires off. that way though you may need a few blocks to reach the ground with the oil pan.
smarter not harder
Old Jan 13, 2005 | 11:35 AM
Rednas's Avatar
Default Re: Hardest way to put an engine in... (ohboy95c)
now thats ghetto
Old Jan 13, 2005 | 12:23 PM
2point2's Avatar
Default Re: Hardest way to put an engine in... (Sand1)
funny, i thought this was the welding/fab threads..
Old Jan 13, 2005 | 01:13 PM
haha 2point2, it is. And yes the 4G63 block is extemely heavy with the crank, rods, and pistons all in it. I dont have a hoist because i have no room for it in my tiny 900sq ft shop. We are getting built onto sometime in the future so then ill have room for one.
The car is on blocks so its easier to work on the body.. i havent driven that car in over a year.
Old Jan 13, 2005 | 01:31 PM
Default Re: (ExploitedRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExploitedRacing &raquo;</TD></TR><TR><TD CLASS="quote">haha 2point2, it is. And yes the 4G63 block is extemely heavy with the crank, rods, and pistons all in it. I dont have a hoist because i have no room for it in my tiny 900sq ft shop. We are getting built onto sometime in the future so then ill have room for one.
The car is on blocks so its easier to work on the body.. i havent driven that car in over a year.</TD></TR></TABLE>
You could fit an engine hoist in there, I've seen people with 1 car storage garages fit a car and use a hoist.
Old Jan 13, 2005 | 02:13 PM
shearerfab's Avatar
Did that monstrosity of an exhaust manifold fit?
Old Jan 13, 2005 | 04:01 PM
I know i can FIT a hoist in my shop.. but i dont feel like having it sit around all the time since i rarely do engine pulls like this.
and that manifold i made i ended up sellin to a guy in Iowa and it just barely fit hah.
Old Jan 13, 2005 | 04:03 PM
They have blow up engine hoist now, of course there jdb. Great technology now a days.
Old Jan 13, 2005 | 04:11 PM
JDB? whaaa
Old Jan 13, 2005 | 04:14 PM
Whoops hit the b instead of the m
Old Jan 13, 2005 | 04:27 PM
93LSivic's Avatar
Default Re: (90blackcrx)
I once pulled an engine out by disassembling.....what a pita.
Why dont you get a collapsible engine hoist. Thats what I have hear at the shop and its takes up exactly 3' x 2.5' of floor space.....not bad at all and fairly inexpensive.
Old Jan 13, 2005 | 06:10 PM
Ill post some pics of the inside of my shop.. ull see how much room i have left over.
Old Jan 13, 2005 | 09:13 PM
mrDFWmechanic's Avatar
damn i bet that **** sux .. i couldn't do that
Old Jan 14, 2005 | 12:09 AM
triple_s1x's Avatar
Default Re: (iROCKtheSOHC)
Doing a bseries in an eg,ek, or integra is quite easy that way. Sometimes using the host on them gets to be more of pain.
Old Jan 14, 2005 | 07:38 AM
JCushing's Avatar
Default Re: (93LSivic)
ive taken out a b series by taking off the head first then lifting the tranny and then the block all by hand all by myself all by lifting out and over the car. i dont think i would ever put it together that way though. props to putting in an iron block by that way lol
Old Jan 14, 2005 | 08:59 AM
evilone's Avatar
Default Re: (JCushing)
you can rent a hoist from pep boys next time.
Old Jan 14, 2005 | 09:11 AM
evilone's Avatar
Default Re: (prostock)
my bad, they don't anymore but a local rental place around here will
Old Jan 14, 2005 | 09:48 AM
Size of my shop...
