DIY crank tool
Old Dec 21, 2004 | 07:34 PM
Anthonyl469's Avatar
Default DIY crank tool
well, ever since i owned a honda I always noticed something about the crank pully....it looked like a nut went on the end...well guess what it does.
I went to my local fasteners store, after i measured the crank pulley
my findings are.
If you buy two 1 1/2 inch "cat" (bulldozer) nuts and weld them together (butt weld)
they fit right in there and you can fit a 19mm socket right in. All you need is a big cresent or pipe wrench, or you could just weld a bar to the end...just thought I should share
Old Dec 21, 2004 | 08:08 PM
Bailhatch's Avatar
Default Re: DIY crank tool (Anthonyl469)
nice, i spent an hour cutting little pieces of 1/4 x 1" stock to make my own "nut" works but your way sounds much easier. good find
Old Dec 21, 2004 | 08:56 PM
sporkcrx's Avatar
Default Re: DIY crank tool (Bailhatch)
I plan to make one for d16a6's since we get screwed on crank tools. We don't have a socket hole or anything. Either going to make it stick into the crank holes, or something to hold the flywheel.
Old Dec 22, 2004 | 09:07 AM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
Default Re: DIY crank tool (sporkcrx)
to hold the flywheel, drill two holes in a piece of flatstock, one for a pressure plate bolt and one for a tranny housing bolt.
Old Dec 22, 2004 | 09:18 AM
Dragline's Avatar
Snap On makes the tool for the crank pulley its like $30
Old Dec 22, 2004 | 09:20 AM
Dragline's Avatar
Default Re: DIY crank tool (mike_belben@yahoo.com)
Thats pretty nice ,Snap on doesn't make the D series one.
Old Dec 22, 2004 | 11:53 AM
cstay's Avatar
Default Re: DIY crank tool (dragline)
also u can just use a old belt like altinator belt. u just need to wrap it around it then let it fold overitself so as it turns it tightens itself then hook it to a bolt and twist away be weary of the belt braking tho
Old Dec 23, 2004 | 08:33 AM
Smashback's Avatar
D and B use the same crank tool. Doh!
On another note...since I got my big *** impact wrench, I wonder why I wasted money on that Moroso crank tool I used to have
Old Dec 23, 2004 | 09:07 AM
im afraid your mistaken. the inner diameter hex is B, the pins are D. look in my photo
Old Dec 23, 2004 | 09:46 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline &raquo;</TD></TR><TR><TD CLASS="quote">Snap On makes the tool for the crank pulley its like $30 </TD></TR></TABLE>
B.S, nothing Snap on makes is that cheap.
Old Dec 23, 2004 | 10:46 AM
AutoLab's Avatar
Default Re: DIY crank tool (90blackcrx)
an easier solution would be a very big set of ChannelLocks. You can get them at Home Depot, get the really large set. They have 'BigAzz' engraved in the side of them
lock the BigAzz's on the smallest ring of the pulley and let it lock up against the lower control arm. Have someone hold the BigAzz's in place, but they will bite themselves. Get out your strong arm and a piece of pipe and go to town.
In the past 4 years I have not had a single crank pulley bolt that the BigAzz's couldnt get off. They are easily 30-0
When done, get some sandpaper and fold it in a V shape and clean up any scuffs you put on the ribs of the pulley.
-bill
Old Dec 23, 2004 | 03:22 PM
zulued's Avatar
Default Re: DIY crank tool (AutoLab)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike_belben@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote">im afraid your mistaken. the inner diameter hex is B, the pins are D. look in my photo</TD></TR></TABLE>
actually i would say that it depends if the vehicle has power stering. ps equiped has the hex pulley the d series with out ps have the holes.
except for the ef d series with ps i dont think they have the hex
i bought my hex tool of the "tool guy" at work it was like 40 bucks.
either way if its 30 or 60 its still worth it if you dont have air tools.
a quick search on google found this
http://www.etoolcart.com/index...D=629
scarponze
Modified by zulued at 7:39 PM 12/23/2004
Old Dec 23, 2004 | 08:54 PM
Smashback's Avatar
Default Re: DIY crank tool (zulued)
Well looks like you called it. I never bought a Honda with power steering ... I figure the way they come our wheezing little motors don't need a bunch of pansy accessories dragging on the crank
All D and B I've worked on worked with the Moroso tool but ... all those D's were manual racks.
Old Dec 23, 2004 | 10:30 PM
if thats true, the top left pulley in my pic was on the wrong vehicle. 95 coupe EX
channel locks are the last tool i would consider correct for pulley removal.
Old Dec 23, 2004 | 11:19 PM
zulued's Avatar
Default Re: (mike_belben@yahoo.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike_belben@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote">if thats true, the top left pulley in my pic was on the wrong vehicle. 95 coupe EX
channel locks are the last tool i would consider correct for pulley removal. </TD></TR></TABLE>
well that pulley only has two belt "lines" on it. all ex/ si's 92-2000 came with ps so either someone else changed the pulley or it could just got mixed up...
and i completely agree with the channel locks. dont use channel locks you dont want to injure yourself using the wrong tool ...
i personally like to use this
scarponze
Old Dec 24, 2004 | 02:54 PM
LD_EGSICK's Avatar
Default Re: (zulued)
i got the same impact gun(good ****)
Old Dec 24, 2004 | 05:18 PM
lsvtec-crx's Avatar
Default Re: (LivinDreamsDC2)
that impact gun is the ****.i just got one a few weeks back and it's great.
Old Dec 29, 2004 | 11:26 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zulued &raquo;</TD></TR><TR><TD CLASS="quote">a quick search on google found this
http://www.etoolcart.com/index...D=629</TD></TR></TABLE>
I have this tool but I bought it from The Tool Warehouse. Only cost $40. I have used it a few times now and it works great.
Old Dec 29, 2004 | 10:02 PM
CivicEKCP's Avatar
This thing is the ****!....Been using this gun for a while now
Old Dec 29, 2004 | 11:02 PM
MrCivic03's Avatar
Default Re: (CivicEKCP)
I also just use a impact gun... its a Snap on one though around 400 bucks...
hey it gets the job done and its super small and will do all things on my civic down to even axles...
Old Dec 30, 2004 | 10:26 PM
havok hybrid's Avatar
Default Re: (MrCivic03)
I just Jam a screw driver in the flywheel... and then use a breaker bar .. works great....
Insert the screw driver where the Dust sheild is... !!!
Old Dec 31, 2004 | 07:25 AM
sander's Avatar
2.7(p/t)
Default Re: (havok hybrid)
http://www.autopart.com/TOOLS/...2.htm
That tool is great, its only $24.xx worked well for me for quite some time.
-s
snapon is good for some things, but be very careful, they often take offbrand stuff and market their name on it and jack up the price.
Its really highway robbery. (not to mention 19.8% interest financing...)
-s
Old Jan 4, 2005 | 04:47 AM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by havok hybrid &raquo;</TD></TR><TR><TD CLASS="quote">I just Jam a screw driver in the flywheel... and then use a breaker bar .. works great....
Insert the screw driver where the Dust sheild is... !!! </TD></TR></TABLE>
I wouldn't do it that way. Here is why... https://honda-tech.com/zerothread?id=957581
Old Jan 4, 2005 | 05:34 AM
19civic93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicEKCP &raquo;</TD></TR><TR><TD CLASS="quote">
This thing is the ****!....Been using this gun for a while now </TD></TR></TABLE>
same one i got too!
Old Jan 4, 2005 | 07:38 AM
xci_ed6's Avatar
Default Re: (19civic93)
Scat makes a tool for VW's that looks like a letter "I" with a hole in the center. you bolt it on to one of the engine-tranny bolt holes and spin it so the pawls enage the flywheel. I have heard it works for Honda's, but haven't picked one up yet.
