compound boost CTSV build.
Old Jan 15, 2012 | 01:20 PM
  #26
MidShipCivic's Avatar
Default Re: compound boost CTSV build.
Originally Posted by TurboFocus
WHO CARES WHAT THE CORRECT TERM IS, this is a fab forum.
Sorry no, this is also a technical forum you don't dismiss 'things'' and deem it useless to re-evaluation. What are you some peanut brain, you don't put any thought behind your work moron?
Old Jan 15, 2012 | 06:06 PM
  #27
TurboFocus's Avatar
LMAO riiiiight
Old Jan 15, 2012 | 06:34 PM
  #28
russianvr4's Avatar
OG Fabricator
gates mounted, working on the recirc back into the exhaust.
once the recirc is done, just hook up the oil lines and weld on the MAF bung, fill up the fluids and off it goes for a fuel system+tune
  #29
russianvr4's Avatar
OG Fabricator
driver side recirc done
Old Jan 16, 2012 | 01:15 AM
  #30
RickyLee53's Avatar
Have you got a pump on the oil return? I think that might give you some hassle.
Also what happened to the lambo build?
Old Jan 16, 2012 | 02:32 AM
  #31
russianvr4's Avatar
OG Fabricator
yeah, pump is already mounted, just need to run lines.
read the thread about it.
Old Jan 16, 2012 | 10:03 AM
  #32
TurboFocus's Avatar
looks good, sure is a tight place to work
Old Jan 16, 2012 | 10:13 PM
  #33
Golfball's Avatar
look good gene.
man scavenger pumps make me nervous after how much trouble they gave us on reza's rear mount tt viper build....
Old Jan 17, 2012 | 02:35 PM
  #34
russianvr4's Avatar
OG Fabricator
thanks Josh, which pump did yall use on his car? what exact problems did you have?
other side is recirc'd
Old Jan 17, 2012 | 05:54 PM
  #35
SovXietday's Avatar
I did a lot of research into pumps and it seems like there is almost no one who has a good answer for dealing with the extremely hot oil going through the pump for long periods of time.
Also saw a few people using the Holley Red fuel pumps with good results, interestingly enough.
Old Jan 17, 2012 | 06:34 PM
  #36
russianvr4's Avatar
OG Fabricator
turbowerx exa pump, look that one up.
Old Jan 18, 2012 | 03:18 AM
  #37
Sobe_Death's Avatar
Nice work!
Ptuning makes a nice turbo kit for the S2000 that has a BEEFY recirc pump included. Might be a start to find one.
*EDIT- It's made by Turbowerx!
Old Jan 18, 2012 | 05:56 AM
  #38
DC47A's Avatar
Turbowerx makes a pretty nice oil scavenge pump. There is also a company on the west coast that makes a nice bronze geared one. They use them on motorcycles and have proven reliable and work great in these kinds of applications. Ive used both on the BMW's with those pesky bottom mounted turbo setups where the oil drain for the turbo almost sits lower than the pan and you have like a 3 to 5 inch drain that is almost lateral with no slope. Just Make a normal drain line to a sump box, then obviously from the sump box to the pump then recirc from the pump back into the pan. It should do exactly what you need. The sump box doesnt even have to be very big. Ill try to dig up some pics.
Old Jan 18, 2012 | 05:57 AM
  #39
DC47A's Avatar
http://www.rbracing-rsr.com/oilsystems.htm
Old Jan 20, 2012 | 11:00 AM
  #40
LMAO riiiiight
Seriously, just stop.
Hey Russianvr4, that brake line going to be okay?
(this picture)
http://i611.photobucket.com/albums/t...V/IMAG0236.jpg
Old Jan 20, 2012 | 09:36 PM
  #41
russianvr4's Avatar
OG Fabricator
been putting finishing touches on it, hoping to fire it up tomorrow.
Old Jan 21, 2012 | 05:48 PM
  #42
Smokinsax's Avatar
The Boot
videos will be a must!
Old Jan 21, 2012 | 05:55 PM
  #43
russianvr4's Avatar
OG Fabricator
shes alive!
http://youtu.be/cmkBNF4Vo_4
Old Jan 21, 2012 | 07:50 PM
  #44
wittyworks's Avatar
Woah sc whine and turbos whistling sounds so sick together. Great Job.
Old Jan 22, 2012 | 03:26 AM
  #45
Tony the Tiger's Avatar
Twincharging in general is when the supercharger is mechanically bypassed and the turbo feeds the motor on the top-end. This gives the low-end of a supercharger and top-end of a turbo. However, you cannot spool a much larger turbo with this setup and maintain its response, because the supercharger is offline before the turbo reaches peak RPM's. There's always going to be a lag spot if the goal was to oversize the turbo well past the original motor recommended displacement and VE, due to the difference of efficiency & power per PSI of boost between the SC vs big turbo(s). For example, putting a 80mm turbo onto a 2.0L motor will create that problem, and it will still lag if you don't allow the turbo to slowly build speed (flat stabbing the throttle at high RPM's after a long decel/coasting). Not much of problem for those with bigger motors though, unless you're trying to put a 3000HP turbo on a 6.0L motor and want to maintain streetability...LOL.
Compound twincharging is when the turbocharger feeds through the supercharger in series, thus, "compounding" two types of boost. 7 PSI pulley + 16 PSI of boost from turbos = 20 PSI of boost against the intake ports. The advantage is much faster spool (positive SC effectively increases VE to the motor, making it behave like a much larger engine), and this effect carries its way through all RPM ranges as long as the SC is functioning. So if you have a 2.0L motor + SC, you can effectively spool a much larger turbo and keep its response, like as if the motor was naturally bigger. However, the supercharger is a big bottle neck, and air temps will become uncontrollable regardless if the SC is aftercooled or not. The outlet pressures from the turbos are also much higher, so you almost have to based your turbo compressor maps differently (probably 1.2x higher on the pressure ratio). The SC's boost is also inefficient, so 20 PSI is not really the same 20 PSI directly from the turbos (e.g. 25 WHP per PSI on turbos, and roughly 10 WHP per PSI on SC), so tuning it seamlessly is a disaster on speed density. Great setup for running fuels that have good cooling (E85) that don't mind a sharp rise in air temps.
With a compound twincharged setup, you won't hear the supercharger whine unfortunately.
Old Jan 24, 2012 | 10:47 PM
  #46
fastrabbit's Avatar
sounds sick...two of my fav sounds
Old Jan 28, 2012 | 04:36 PM
  #47
slytheslayer's Avatar
This is going to be Silly fast! Nice work!
Old Jan 28, 2012 | 06:04 PM
  #48
FabChild's Avatar
good job man, sure looks tight fitting all that in there. How many hours do you have in this build?
Old Jan 28, 2012 | 06:59 PM
  #49
russianvr4's Avatar
OG Fabricator
hmm, hard to say since i've been working on it mainly after hrs, i'd say 60ish?
Old Jan 28, 2012 | 10:15 PM
  #50
FabChild's Avatar
Awesome, it def. looks good
