can a crack on the outside of a block be fixed?
Old Apr 18, 2008 | 12:07 PM
ivan93egreppin210's Avatar
Default can a crack on the outside of a block be fixed?
my b20b has a hairline crack where the oil pressure sending unit is.not in the threads but on the top. oil only drips when the motor is on. i have since replaced the shortblock. since the old block is just sitting there i wondered if it can be salvaged?
Old Apr 18, 2008 | 01:21 PM
pornstarSR's Avatar
Default Re: can a crack on the outside of a block be fixed? (ivan93egreppin210)
something similar happened to a buddies block.
i welded it, and we retapped it and it worked for at least a year, till he swapped out for a different motor config.
you can fix it. but its not a jb weld fix
Old Apr 18, 2008 | 01:25 PM
Default Re: can a crack on the outside of a block be fixed? (pornstarSR)
yes sir. if i welded it , it would be done by a shop that knew what it was doing. what type of materieal is the block made out of? is it just alluminum or is it a diffrent type of alloy? is there a special type of welding material involved? thanks pornstar.
Old Apr 18, 2008 | 02:24 PM
qksl2's Avatar
Aluminum, I had the best luck with 4043. Dirty but it welds ok.
Ian
Old Apr 18, 2008 | 02:35 PM
Default Re: can a crack on the outside of a block be fixed? (qksl2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qksl2 &raquo;</TD></TR><TR><TD CLASS="quote">Aluminum, I had the best luck with 4043. Dirty but it welds ok.
Ian</TD></TR></TABLE>thanks ian. i will bump this post up again in a few weeks after i get the time/funds to have it welded. thanks welding/fab forum.
Old May 5, 2009 | 09:35 PM
bummping this thread back up from a year ago so i dont make a new thread............
NEW QUESTION.....how can i pressure test the short block after i have it welded? and should i take it to a radiator repair shop? seems like they might be good at welding aluminum. thanks.
Old May 6, 2009 | 09:11 AM
jlude90's Avatar
i'd go for a cylinder head repair shop
Old May 6, 2009 | 09:13 AM
aristro's Avatar
I beg to differ. I JB welded my block and it held for 9 months! I wouldn't suggest it but it worked
Old May 6, 2009 | 02:25 PM
lol jb weld kicks ***. i used to have an unopened tube in my trunk. came in handy when my old radiator cracked as a temp fix to get me home. i wouldnt use it on my block.......
will a cylinder head repair shop be able to pressure test my block?
Old May 6, 2009 | 07:43 PM
jlude90's Avatar
if theres no holes, i don't think a pressure test is necessary, you don't build up too much pressure in the crankcase
Old May 6, 2009 | 08:34 PM
its right on the oil pressure sending unit. so i guess it would just need to be strong enough to hold oil pressure, not crancase pressure. is there a difference?
Old May 6, 2009 | 08:42 PM
jlude90's Avatar
yeah, lots of difference, oil pressure peaks at 80ish and is usually constant 60ish
crankcase pressure shouldn't be that high though
Old May 6, 2009 | 10:05 PM
Garage 808 Hatch's Avatar
i JB welded a 5" crack accross the front of my sleeved B16 in the water Jacket. it held numerous heat cycles, and a dyno session. ended up pulling it for other reasons. I love JB weld. (we did try to tig it, but the crack kept spreading)
Mattb16teg
Sep 26, 2008 07:25 AM
Kjetil
Feb 26, 2007 12:37 PM
ThatsMyEG
Aug 8, 2005 08:32 PM
CL SLeePeR
Apr 21, 2005 05:15 AM
blk02ep3
Dec 21, 2004 06:52 PM
