Another small cnc project
A customer of mine is building a MKIII supra with a 2JZ in it. I made this so he can install his new fuel system using the stock tank. Holes are cut for a -10 feed and -6 return bulkhead fittings. I also made a second one in case he changes his mind and decided to sump the tank.
Not really. 1/4" hss endmill @ 5100 rpm, 45ipm, max DOC of 0.08 with 35% step over. I could have done it a lot more efficiently but as it was a one off I wasn't concerned about cycle times and wanted to limit the tool changes so I could go do something else.
doesnt it need more holes for the little gasket deal? i just made a pickup for a mk3 supra with a 2j too but just welded fittings and the pickup to the stock lid.
I actually counted them 3 times because it seemed odd that there were 7 of them.
I was actually thinking about it. This seams like the sort of thing that would come in handy to a fair number of people.
Probably could have used 3/4 endmill and had a much better finish and 1/4 the cycle time. It alsmost looks like you surfaced the whole thing lol, seems like a weird pattern even for a 1/4 endmill, looks more like a ball nose.
I just double checked the math and your right, 0.0022 ipt (0.0086 ipr) is fairly aggressive. I do so much work with 1/4" end mills that I've gotten into the habit of pushing them pretty hard, so to me that was a medium cut. But yes I'm sure it was deflecting the cutter, especially as I normally use cheap hss cutter because they take more punishment before breaking.
Some of it is the machine, 2" from the spindle nose I will measure 0.0005"-0.001" of run out. Part of this may be the head being slightly out of line but some of it is also the holders and them getting worn. One of these days I'll deal with it, and upgrade to a bt30 spindle. For now she still holds 0.001" which is more then enough for the work I'm doing.
Yeah or in the least a 1/2 inch, but as I said I wasn't worried about cycle times. I don't have an ATC so I just coded it to do everything with the smallest cutter needed and walked away. If I was doing a run of these I'd switch to a 1/2 carbide and maybe even do both a roughing and finishing pass.
At 45ipm on a .250 cutter, you are running over .008"per rev, and it looks like it was a 2 flute so basically .004" chip load per tooth per rev. That is really aggressive for a HSS em, especially a small .250" one. Sound like carbide feeds.
does rosseta stone have this language on cd cause i dont know what the hell you guys are sayin, but the part looks good and im jealous, i want a cnc mill.
Anyways, if you want a real machine just buy my Matsuura
I'm actually thinking of selling it, we should talk.
Dave, looks like surfacing on my phone lol, I've never seen any step over that close together, but I believe him if its a standard endmill. Maybe there was a radius on the cutter and that's why the close stepover?
Makes more sense with no tool changer, are you running a cnc bridgeport or something?
?? I think maybe you are getting some of your terminology mixed up, this part has a decent size step over, he said his woc was 35% cutter di.
Small step over is like .010" and under, that is a surfacing stepover.
It looks more than anything some sort of tool deflection, which is why I guessed aggressive feed. If you put a lot of chip load on those small cutters they flex a lot. The part looks like either someone hand scraped it or tig welded the top, I actually kind of like it.
Maybe its just hard to tell how big the part is but usually the parts I make you can see basically the whole cutters diameter with each step over, maybe its just because I rarely use 1/4 endmills for anything but small counterbores and cutting a radius so it looks weird to me. What's the diameter on the part? 3"?
Actually now that I think about it its probably more like 75% of the tools diameter, sorry I don't do any programmming just setup and running the parts. So I guess I would expect it to look like 3/16th stepover?
How the hell did you sneak that post in there? Maybe somethign is jacked with my computer, but I posted up my post about chiploads and your post mentioning the same thing was not there... weird.
As I've said I'd be very interested in your machine. I'd actually rather have your machine then a newer Haas TM-1. A second machine is not going to be the sort of thing I can swing over night. I'm pretty sure I'll have to upgrade my current slab to hold a machine that size, but depending on what kind of time frame you are looking to sell it in we might be able to work something out. I'm about 30 mins away from you so sometime when we both have some time to spare I'd love to come by the shop and check out the machine. I've only ever used the machine I have so I'm very curious as to what it's like to operate a larger machine.
THanks
LOL we must have been writing at the same time.
if your looking for a good machine for a good price look into a matsuura ra2 they have pallet shuttles on them. i use 2 of them at work from the early 90's good solid machines but not at fast as the mori nv5000 or the haas vf2 that we have. its a good bang for the buck
The ra's you run, are they yasnac mx1-3 or the i-80 control?
