another pie cut question
Old Nov 25, 2009 | 06:57 AM
VtecFreePrelude's Avatar
Default another pie cut question
just curious about the basic setup for piecuts. like i know the formula but not sure how big each piece should be... and if the straight end should be cut at an angle or not...
thanks
Old Nov 25, 2009 | 07:12 AM
GTibunny16v's Avatar
Default Re: another pie cut question
That is all up to the tube you're trying to produce. I pretty much eye ball it every time, just use some PVC pipe to do a quick mock up to make sure the angles are right if you're not comfortable just hacking into some more expensive tubing.
Old Nov 28, 2009 | 10:31 AM
Fabworx's Avatar
just depends on how nice or how radical you want it to look, patience is key!!!
AM_H2B
Welding / Fabrication
Feb 6, 2015 01:04 PM
MidShipCivic
Dec 10, 2007 11:16 AM
EdsGTI
May 24, 2007 10:21 PM
RCautoworks
Apr 13, 2006 08:42 PM
