Which aluminum?
So I would like to get an aluminum sheet to make a skidplate. I would still like to be able to bend it and it will need to be welded in two spots. Here are the grades of aluminum I am able to get through a local supplier. Which should I buy? I think i will be getting 3/16" unless anyone can convince me otherwise. Cost is a factor as well.
aluminum sheet - mill finish non heat treatable
1100-H14
3003-H14
5052-H32
aluminum sheet mill finish heat treatable
6061-T6
1100-H14
3003-H14
5052-H32
6061-T6
5052 is susceptible to tight radius cracking also, try to organise bending so that it has a good radius and also so the bends are across the rolled grain of the plate rather than along the grain.
5005 isn't available over there? it's my choice of a good middle of the range alloy for fabrication, particularly the fuel tanks we build.
Here in Oz we don't get any of the 3003 alloy which is a shame as it's ideally suited for rocker cover (valve cover for you guys) fabrication.
Regards Andrew from Oz.
hondakevin21
Welding / Fabrication
Jan 8, 2007 01:11 PM
ungcobob
Nov 9, 2006 02:07 PM
