Ring Gear Binding on Shift Fork
Just swapped the ring gear with a ZC ring gear on the SI diff so I can use oem axles with my ZC tranny and now it’s binding on whatever that part is called, first time doing a transmission and it’s been great up to this point, please help
Is the bolt missing from the shift change piece to the shaft ? This would hold it closer to the case edge and thus would move it away from the ring gear so it would not make contact.
