Transmission & Drivetrain Gearboxes, Differentials, Clutches
ISB seal question...
Old Oct 21, 2009 | 06:14 PM
iCollectStraws's Avatar
Default ISB seal question...
D16z6 5-speed
How bad does it need to be damaged to start leaking?
I recently replaced the ISB in my tranny and while sliding the mainshaft back in the teeth on the end clipped the new seal and tore it a little on the inside on the side of the seal facing up towards the shaft. I needed the car ASAP and installed the tranny anyway. I know the obvious is that I should have replaced it again while it was out but I didn't have time to wait a few days for the new one to be shipped. It's been 2 days since the repair and there haven't been any leaks as of yet.
Is it gonna get worse overtime and am I looking at a future where I'll be dropping the tranny again soon?...
Old Oct 21, 2009 | 07:19 PM
night's Avatar
Default Re: ISB seal question...
bit of a pointless question.
either take it out and fix it now or wait and see.
Old Oct 21, 2009 | 07:40 PM
Aquafina's Avatar
If you tore the seal you need to replace it. Most dealerships have them in stock, if not it takes them a day to get it unless you're in the boonies.
Old Oct 21, 2009 | 08:28 PM
Pointless maybe, Ive seen worse questions.
I just wanted to know how much wear it takes to leak. Like those who have pulled a leaking one out maybe they could give me insight into how bad it looked.
Old Oct 21, 2009 | 08:42 PM
night's Avatar
ummm.. i fix honda's all day every day and when i take one out that leaks i don't look at it, i throw it away.
seals are changed for age and brittle rubber. no one can gauge a cut and how bad yours is going to be.
Old Oct 21, 2009 | 09:13 PM
Alright I see your point. Guess Ill just check for leaks from time to time. Until then im not pulling the tranny back out.
Integra4lyfe069
May 26, 2010 05:15 PM
91civicsikid
Feb 13, 2008 06:29 PM
92-LS-Civic
Dec 6, 2004 08:35 PM
civbeater90
Jun 20, 2003 09:50 AM
