Transmission & Drivetrain Gearboxes, Differentials, Clutches
How to convert cable trans to hydro?!?
Old Mar 2, 2009 | 07:09 PM
scspeed's Avatar
Default How to convert cable trans to hydro?!?
Hey guys, my friend has a b16 cable trans, we ant to convert it to hydro. We have access to a hydro transmission case, but something tells me that it wont be as easy as just swapping the internals...
I know there is two ***** with springs on hydros for the gear changing, and on cable there is only one...and sometimes none. So how would i go about doing this??
Also how would i go about shimming from roller bearings to ball bearings in the dif from the b16??
Is there a kit i should buy? HELP!!
Old Mar 3, 2009 | 04:57 AM
scspeed's Avatar
Default Re: How to convert cable trans to hydro?!?
Anybody??
Old Mar 3, 2009 | 05:56 PM
scspeed's Avatar
Sombody on honda tech HAS to knoww
Old Mar 4, 2009 | 07:35 PM
Gearspeed-Performance's Avatar
First which B16 cable trans is it?
YS-1, Y-1, S-1, J-1?
If it is a YS-1 it is a matter of swapping a few items.
If it is the others...not gonna happen...they are not interchangeable.
Old Mar 8, 2009 | 06:55 PM
1990_integra_DA9's Avatar
Hasport Makes a conversion kit. No need to swap internals. All it is, is a bracket that bolts to where the Slave Cylinder is on the side of the trans. I had one on my GSR motor i had in my ls. It uses the Factory Clutch cable. Its quite simple. If a gsr one works with a b16 tranny ill sell u mine with a hasport mount of the tranny side....
scooterbuilteh2
Jan 9, 2010 04:38 PM
scspeed
Mar 6, 2009 02:50 PM
scspeed
Mar 4, 2009 07:28 AM
