Transmission & Drivetrain Gearboxes, Differentials, Clutches
help with final drive
Old Jun 4, 2009 | 04:53 PM
atlplayer4life90's Avatar
Default help with final drive
i was wondering i have a JDM type r integra tranny with a 4.4 lsd final drive and i have been looking at the m factory 4.9 final drive would this fit my tranny, what would be some out comes, should i spend the money, all help is highly appreciated thanks guys
Old Jun 4, 2009 | 08:32 PM
KIWI's Avatar
Default Re: help with final drive
Yes it will fit, so will GEAR-X, ATS or Carbonetic as far as the ratio is concerned, it depends on what you want to do with your car. Is it a daily Driver? If so, a 4.9 will be fine and you will have great acceleration. You might want to get a GEAR-X 3.07 First gear as well. Just icing on the cake.
Kiwi
Old Jun 4, 2009 | 08:48 PM
MFactory's Avatar
What application will it be for? Street car? Occasional Track Day? Drag?
To determine the speed vs rpm, have a play around with our Gear Calculator
To determine the torque increases, have a play around with our Torque Calculator
HTH
Old Jun 4, 2009 | 11:50 PM
thanks for the replys now what else would i need in order to install the final drive cause ive seen some companies say that you need needle pins and such things, the car is just a weekend warrior, drag racing, street racing no daily just fun. thanks for all the input, and what an average price i could be paying to get this installed..
Old Jun 5, 2009 | 12:18 AM
Mista Bone's Avatar
D Tranny Guru
which ever company's FD gearset, (I'm parcel to GearX, either company is fine) figure might as well replace input shaft bearing and all four seals while tranny is apart, inspect everything else.
Someone like me, looking about $150 + parts for install. Depending on your location in GA, Aquafina who sells MFactory is in TN and can do the install.
LOL, so much smoother without the bashing...I like it this way!
Bobismoi
Jun 4, 2007 05:47 PM
Jimmy
Oct 12, 2006 02:00 PM
kuki
Apr 9, 2006 01:56 PM
