Transmission & Drivetrain Gearboxes, Differentials, Clutches
gear swaps
Old Apr 16, 2011 | 01:06 PM
grant97teg's Avatar
Default gear swaps
My ? Is that I have a 96 dx tranny and a 97 ex tranny. I'd like to just swap my 5th gear from my dx and 1-4 off the ex. So I was wondering if I can just swap the 5th gear or do I need to swap the main shaft or ring gear so my final drive isn't diff? Also are the diameters of the shafts the same for the bearings?
Old Apr 16, 2011 | 03:40 PM
Aquafina's Avatar
Default Re: gear swaps
5th gear is the same.
You can use whichever FD you want, but ring gear and countershaft have to be kept together. Shaft diameters are the same, but bearing OD is not.
Old Apr 16, 2011 | 03:55 PM
grant97teg's Avatar
What can I swap to keep the fifth gear final drive? Couple places state the final drives between the two are diff
Old Apr 17, 2011 | 04:55 AM
94EG8's Avatar
Seagull Management
Both 5th gears are identical in every way. Older D-series Si transmissions in the '92 - '95 Si and Del Sol Si had a slightly lower fifth than the DX (and apparently EX coupes/sedans, which used a transmission otherwise identical to the Si)
If you're trying to lower your RPM in 5th you'll need to swap the final drive, it's going to make your gearing longer/higher for all gears though.
cordillera auto
Jun 13, 2019 12:40 PM
0ne-Cam
Apr 14, 2011 05:25 AM
brlabrune
Feb 23, 2009 12:37 PM
cgo_62
Sep 24, 2006 09:26 AM
JDMkidGSR
Jul 2, 2004 05:46 AM
