Transmission & Drivetrain Gearboxes, Differentials, Clutches
Countershaft teeth
Old Jun 19, 2014 | 07:57 PM
KENetics1's Avatar
Default Countershaft teeth
These are wear marks on my ats 4.9 final drive where the ring gear contacts the countershaft. Is this still considered usable or is it damaged beyond use?
Old Jun 19, 2014 | 09:51 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Countershaft teeth
Time for a replacement.
I've replaced ATS and SRR gear sets because the pinions that have done that.
Old Jun 20, 2014 | 11:46 PM
slowcivic2k's Avatar
Replacement for sure, the teeth have either sunk too far into the root of the gear and caused permanent damage to it, or excessive power has caused permanent moving of the tooth itself. The wear does look uniform, which would suggest the pair was too closely spaced to begin with, but I see no wear on the top of the tooth to indicate interference. This must simply be overload or inferior materials. I would doubt any repositioning would have changed the outcome, only the location of the stress.
Please specify your power and usage so others may reference this picture in the future. Also is the damage concentric? Does it vary in any given gear tooth, etc.
Old Jun 21, 2014 | 11:43 PM
Mista Bone's Avatar
D Tranny Guru
SRR pinion that was replaced with a Gear-X FD....
Old Jun 23, 2014 | 11:25 AM
Aquafina's Avatar
Replace it. I've replaced a lot of broken ATS FD's.
092eg6
Dec 15, 2009 07:01 PM
HATCHY on BOOSTY
Jan 20, 2004 07:48 AM
Jared
Mar 15, 2003 02:18 PM
Dorikamu
Jun 20, 2002 11:39 AM
R2D2
Jun 17, 2002 07:40 AM
