Carbonetics LSD Noises?
http://www.carbonetic.net/products/lsdoil.html
Clutch type LSD's need a specific oil per manufacturer. Most clutch types will make noise when cold and low speed sharp corners as well.
It could be a mismatch of LSD oil. However, the noise of the carbon LSD is not influenced by the choice of oil as much as the noise of a metal LSD. When did the cranking noise start?? Did it start right after you installed it??
