Transmission & Drivetrain Gearboxes, Differentials, Clutches
Big d tranny problems
Old Apr 13, 2014 | 03:49 PM
ek9monster's Avatar
Default Big d tranny problems
I have. 98 civic dx 1.6 auto non vtec I'm having trans problems it won't shift into all the gears stays in 1st when put in drive. I have replaced the trans 3 times and there is no way I bought 3 bad trans and replaced the ecu and the levels are all good. And my speedo stopped too. Help???!!!!
Old Apr 13, 2014 | 04:23 PM
Discosteak's Avatar
Default Re: Big d tranny problems
Worst thread title on earth............
Have you tried shifting it manually? sounds like an electrical problem
Old Apr 13, 2014 | 09:08 PM
slowcivic2k's Avatar
You most likely will have trouble codes present that will at least point you in some direction. A failure to engage a gear when commanded will produce a trouble code.
Check fluid level, and ensure the correct fluid is being used.
As for the speedo, check the sensor and the plug, has nothing to do with shifting.
ek9monster
Apr 14, 2014 06:31 AM
specialty
Honda CR-V & Element
Oct 16, 2012 05:37 AM
Thunder Cat
Feb 24, 2007 07:49 AM
high-octane
10
Aug 27, 2006 11:28 AM
sxecustoms
Acura TL, RL & ZDX
Dec 21, 2003 07:32 PM
