Transmission & Drivetrain Gearboxes, Differentials, Clutches
B16 outer trans case install
Old Mar 12, 2014 | 08:32 AM
miked123's Avatar
Default B16 outer trans case install
Lookin for some info on how to install the outer trans case. I've read the right up but still seems like I'm doing something wrong. I get the case on fine but when I tighten the bolts down the spot on the case that holds te shift rod in place keeps cracking off. Please someone help me out.
Old Mar 12, 2014 | 01:42 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: B16 outer trans case install
You have to have everything aligned, including the shift rod when dropping the case on.
NEVER use the bolts to pull the cases together....
hmongxcuz
Jan 16, 2008 02:21 PM
zangiefisgod
Feb 28, 2006 05:46 PM
GSRCRXsi
Oct 7, 2005 09:23 AM
RedEj8
14
Jun 3, 2005 03:01 PM
