Texas -OK -LA (Sales) Texas, Oklahoma, Louisiana
crx jdm b16a ys1 tranny
Old Aug 5, 2007 | 05:18 PM
boliver shagnasty's Avatar
Default crx jdm b16a ys1 tranny
I'm selling my 1988 Honda CRX Si VIN # JHMED9365JS009361, The car has a clean title, no accidents, and I'm the second owner. The car has approx. 220k Miles on the chasis.
The interior is VERY CLEAN, the car has NO RUST, ENGINE, TRANNY, and SUPSENSION are what I've thrown most of my money into. The electronics have been converted to OBD1.
The engine block was freshened up with all new parts except the oil pump and bearings. The head was pulled off, rebuilt and resurfaced. The YS1 tranny was rebuilt with NEW bearings,seals, TYPE R LSD and also NEW LS 5th gears which makes for pleasant highway driving.
The A/C system has a full charge and has a new HCP A/C bracket,compressor,dryer,seals etc. works good! Sunroof works too...
Over the years I've invested almost $8,000 on restoring this fun car(That does not include the CAR or LABOR.) It may not seem like it at first glance, but all the parts add up quick!...and I feel I put most of my money where it counts.
FYI I have a stack of receipts for the parts I've purchased..
The car is almost 20 years old! Thats why I felt I should replace the entire suspension with new components. I've also upgraded the brake system to the Bigger Integra full Disk brake system with slotted rotors and performance brake pads.
the car has brand new black paint. It has dings here and there, but nothing major.
I'm asking $5500, feel free to contact me if your interested or have any questions.
Stuff done to the car:
TRANNY
92-93 Integra GSR YS1 cable transmission with ITR LSD
new seals
New GSR throw-out bearing
NEW main & counter shaft bearings
NEW 92-93 LS 5th gears
NEW Diff. bearings
ACT Steet disc and Heavy Duty P/Plate
Fidanza Aluminum 2 peice flywheel 8lb.
ENGINE
JDM B16A DOHC engine
HASPORT MOUNT KIT
timming belt
water pump
valve cover gasket set
vtec solenoid gasket
cam seals & cam plug
distributor seal
front & rear engine main seals
trans axles seals
intake manifold gasket
throttle body gasket
valve seals
rebuilt & resurfaced head
oil pan gasket
used 95 Acura Integra GSR camshafts
GSR thermostat
A/C SYS. (all new parts)
HCP A/C bracket
A/C compressor
A/C drier can
A/C o-ring set
A/C evaporator expansion valve
A/C refill n inspection
High performance brass/copper dual core radiator
MISC.
B&M adjustable fuel pressure regulator
B&M fuel pressure gauge
Autometer oil pressure gauge
Autometer engine temp. gauge
OBD0 to OBD1 conversion w/ 4-wire heated 02 sensor
OBD1 P72 GSR ecu
SUSPENSION
NEW 93 Integra Axles
NEW 93 Integra front wheel bearings
NEW outter tie rod ends
NEW front lower control arm bushings
NEW front sway bar bushings
NEW front ball joints
NEW Ingalls front camber kit.
NEW TEIN SS Dampers/Coilovers
New Rear upper & lower control arms
New Rear trailing arm bushings
New rear Wheel bearings
BRAKE SYS.
93 Integra Front big brake conversion rotors & 91 EX hubs
93 Integra Power Slot rotors
93 Axiss Brake pads
93 Integra rear disc brake conversion
93 Big Brake booster and New master cylinder
INTERIOR/EXTERIOR
Brand new black paint
JDM CRX SIR frront seats (like new)
99 civic Si armrest
Python Security system with keyless entry
JDM CRX Si gauge Cluster Khm and 8K redline
Energy Suspension Shifter bushing kit.
JDM CRX Si front bumper with Yellow Stanley fog lamps
alpine head unit
infinity kappa speakers
asking 5,500 obo
questions - email me at amar.dhingra-1@ou.edu
[IMG]http://a448.ac-images.myspacec...f.jpg[/IMG]
http://a554.ac-images.myspacec...9.jpg
http://www.we-todd-did-racing....x.jpg
http://a844.ac-images.myspacec...b.jpg
Modified by Boosted D at 6:30 PM 8/5/2007
Old Aug 6, 2007 | 09:56 PM
he's so JDM's Avatar
Default Re: crx jdm b16a ys1 tranny (Boosted D)
where at in tejas are you? im gonna take a road trip with my girl to S.A to visit friends and i wanted to see if i can come look at it if you still have it by the weekend?
evo8psi23
May 31, 2008 10:59 AM
lowbudget88si
May 1, 2006 07:53 AM
lvbuckeye
Apr 11, 2004 07:41 PM
swoosh
Mar 20, 2004 05:02 PM
LowSiR
Jun 22, 2001 10:02 AM
