z6 head and pm6 ecu
i have a 90 civic std with d15b1 engine. i want to put a z6 head but im searching yesterday and from what i read, p26 ecu is better but the problem is its obd1 while my harness is odb0. i think its a hassle to convert obd0 to obd1. what do you think?
you can actualy chip some obd0 ecus. it will work but not perfect.
your changing up compression which would need a custom bin.
you can chip an obd0 ecu and jus ask xenocron.com to make you a map(bin) aka chip to your specs for $30 and send it to you.
plug in the chip and away you go
4door93civic
Jul 21, 2004 12:16 AM
