Would I benefit from Prelude injectors?
Old Dec 30, 2003 | 06:27 PM
lilredhatch's Avatar
Default Would I benefit from Prelude injectors?
They're 270cc and mine are 240(B18C1) right? Would it be worth it w/ a small all motor set up? Cams, cam gears, springs, retainers, Skunk manifold, bigger T/B, S-AFC, programmed P28, I,H,E, Fuel P R,
Old Dec 30, 2003 | 06:33 PM
non-VTEC's Avatar
Default Re: Would I benefit from Prelude injectors? (lilredhatch)
last time i checked the 97+ prelude injectors are 290cc.
and yes your setup could probably benefit from them if you get it properly tuned with a widband o2 sensor on a dyno.......
HTH
Old Dec 30, 2003 | 06:39 PM
Default Re: Would I benefit from Prelude injectors? (non-VTEC)
My bad, i thought they were 270. I've heard a lot about a wide band O2 sensor. What exactly is that?
Old Dec 30, 2003 | 06:42 PM
HamiltonRex's Avatar
I always thought a o2 sensor was a o2 sensor pretty much.
Id like to know about the wideband also!
-Eric
Old Dec 30, 2003 | 06:51 PM
non-VTEC's Avatar
Default Re: Would I benefit from Prelude injectors? (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">Id like to know about the wideband also!
-Eric</TD></TR></TABLE>
this will tell you what a widband o2 sensor is: https://honda-tech.com/zerosearch
Old Dec 31, 2003 | 01:39 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">last time i checked the 97+ prelude injectors are 290cc.
I believe the OBD1 prelude injectors are 290cc. For whatever reasons, Honda went back to 270cc (or 240cc...forgot) for OBD2 prelude engines.
dohcvtecpower
May 7, 2009 07:41 PM
JDMF22B
Oct 10, 2004 03:33 PM
racer505
Oct 10, 2003 05:54 PM
Austin
Oct 29, 2002 01:58 PM
