Wiring problem
Old Sep 18, 2006 | 01:12 PM
zex_cool's Avatar
Default Wiring problem
Little background info. I have a 97 civic with a recently swapped z6 with my obd2 harness. Im running a chipped po6 with a z6/450cc base map.
Problem, I have a check engine light for vtec spool solenoid valve and vtec pressure valve.
I have the wire from the solenoid coming directly to the vtec wire on the obd2 to obd1 conversion harness. I also have the power wire for the pressure sensor wired in the same way.
Idk where I should connect the ground for the pressure sensor. I tried just doing it on the battery but nothing happens.
I soldered all of my wires together but still have the two engine lights. Need help.
Old Sep 19, 2006 | 06:20 AM
so lazy's Avatar
Default Re: Wiring problem (zex_cool)
dont know what to say because on a recent lsvtec swap i did i ran rad the grounf str8 to the battery.. are you sure your wiring your vtec and pressure switch right into the harness?
Old Sep 19, 2006 | 06:22 AM
so lazy's Avatar
also i dont usually run it to the conversion harness i run it to the ecu plugs to make it look clean.. and you can really read what pinouts the wires are to go..
Old Sep 19, 2006 | 10:11 AM
zex_cool's Avatar
Default Re: Wiring problem (dc2-guy)
i got it figured out. i had my oil pres. wire soldered to a wrong wire. thanks.
psychocarne
Oct 21, 2012 03:47 PM
03EM2guy
Apr 19, 2011 01:17 PM
slow_cx
Aug 22, 2007 11:11 AM
Charbon Sty
May 4, 2007 10:35 PM
ek9vboi2
Jun 24, 2005 07:44 PM
