Will switching to OBD-I solve my problem?
Car- 96 Integra LS
I am trying to pass NJ state inspection. Car is throwing CEL code for 02 sensors, if I convert to OBD I (harness and ECU) will the codes be gone?
Anyone who can help please do
i'm not sure but i think that obd1 only supports one o2. your best bet would be to get a o2 simulator. it basically fools the ecu into thinking that the o2 is their and working. in turn it wont throw codes. i have the same problom on my 00 SI i converted it to obd1(harness), but it still throws codes. i was told the best thing to do is to buy a high flow cat like random technologies or catco. it will still support the o2 without losing to much power from a factory cat. you should be able to test and pass with it, as it is a replacement(free flowing just a bonus). just make sure that when you erase the codes that you give the car a little while before going into inspection(codes sometimes stay stored in memory for awhile)( a week at least is what i did and passed with a test pipe!!!!!!!!!!! he he he, i dont advise trying to pass this way though i think i just got lucky.)i hope some of this info has helped if not i deserve to be shoot down. just my bit. good luck
