Will d15 rod bearings fit a d16???
None of the stores can get d16 rod bearings, but advance can get d15's for like $27. honda can order the d16's but i'll have to wait a week and dont have the time to do so. Any suggestions on where to get them??
THanks
Burke
THanks
Burke
engine #'s as in d15b7 and d16z6. ive been searching through helms and cant seem to find rod diam anywhere. i just found it odd that they can get d15 bearings but not d16. oh well.........
They might be the same for all d-series 99% sure. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES »</TD></TR><TR><TD CLASS="quote">before you can order bearings for your car, you have to take the motor apart. There is a number on the rod, crank and inside of the block...those numbers tell you what bearings to run...
...Honda has them sorted for blueprinting from the factory</TD></TR></TABLE>
order them from the dealer for that reason. hit up BERT-O he can get them for under $10ea. don't quote me though
i know the whole color coding. but i took out the rods in haste and dont know which were which. i just want a generic set for the time being. i hit up bert o
thanks
Burke
thanks
Burke
Sorry for not being clear, the rod housing bore is larger and the crank is larger for most of the D-16 VS the D15, get the correct parts. The cylinder bores are the same.
1point7db2
Mar 29, 2006 10:10 AM
