Will b16 pistons fit in a d16y8?
Old Jan 13, 2006 | 05:26 PM
madEGhatch05's Avatar
Default Will b16 pistons fit in a d16y8?
ive done some research on what pistons to put in my single cam. i was originally going to use the d16a1 pistons out of the old dohc motors in the old integras. they are basically the same pistons as those in the jdm dohc zc motor. but instead, i want to maybe go with b16 pistons. the usdm version (pr3) not jdm (p30). i have a y8 block and im going to use a z6 head so i dont have to go through changing to obd2. i noticed that the b16 pistons are a bit taller than sohc pistons. is there any rod combo with b16 pistons that would work?
thanks,
mike
Old Jan 13, 2006 | 05:36 PM
mmuller's Avatar
Mad Scientist
Default Re: Will b16 pistons fit in a d16y8? (madEGhatch05)
no you cant; there is 6 mm bore difference. 75 vs. 81
Old Jan 13, 2006 | 09:25 PM
89s1's Avatar
pr3 and p30 has nothing to do with if it is a jdm engine or not, they are just different pistons for the jdm 1st gen and second gen.
Old Jan 15, 2006 | 05:43 PM
eg6vtec1's Avatar
Default Re: Will b16 pistons fit in a d16y8? (89s1)
Ive heard that if you sleeve the block you can bore to 81mm, but i just heard that not sure if you actually can
Old Jan 15, 2006 | 06:14 PM
v4lu3s's Avatar
RTFM
to get 812mm bore in a d16 you will need a custom crank.
79mm bore is the largest i ahve seen possible without the crank work.
GSR_EJ
Dec 23, 2009 04:33 PM
BoostedEF
Oct 24, 2005 05:51 PM
gocivicgo
Jul 16, 2003 12:09 PM
EFing8
Apr 3, 2003 10:32 AM
