why wouldnt my fuel pump turn on?
check the main relay its controls ground for the ecu and fuel pump. the solder joints get loose when they heat up. you can resolder the joints that get loose from heating up and cooling down. its all pretty simple. Also check the fuel pump. but its usually the main relay. this happen in mostly the 00 and lower civics and accords 00 and lower and preludes.
92hatchboi
11
Apr 24, 2007 07:59 AM
