Where is everyone mounting their water temp sensor?
Old May 1, 2012 | 09:25 PM
got-vtec?'s Avatar
Default Where is everyone mounting their water temp sensor?
I just bought a autometer water temp gauge. It came with fittings but I cant find a spot to screw it into. I would say install inline with the radiator hose with a pipe and bung but then that wouldnt be reading the temp of the block/head.
Old May 9, 2012 | 07:39 AM
d1ck's Avatar
Default Re: Where is everyone mounting their water temp sensor?
That wouldn't be a good place to mount it as the coolant only flows through that pipe when the thermostat is open.
Old May 13, 2012 | 09:08 PM
Blaze45's Avatar
Brrraaaap!
I used the stock position on the head. The head has metric threads and the sensor is NPT from the short sweet electrical gauge. I just used some RVT and screwed it in a few threads till it got tight and called it good. 20k on one engine and 10k on another and I never had an issue. If you are using the mechanical gauge, the only way that I know of to get a proper reading is to tap the top hose that goes from the head to the radiator.
Slacker93eg
Apr 5, 2014 08:23 AM
JBLAZE622
Mar 22, 2009 06:26 AM
innes887
23
Jun 21, 2007 10:54 AM
h-t sucks
Aug 5, 2005 05:09 PM
whitecrx
Aug 3, 2005 09:53 AM
