When swapping out radiators..
..is it necessary for me to drain the coolant from the engine block, via the drainage bolt? Additionaly, how do I bleed the coolant system for air bubbles?
when you put in the new radiator,fill up the radiator and start the car and let it idle to normal temp. then refill as it goes down and watch the airbubbles come out. then put back cap and you're good to go
