What's the CR of this set up?
whats the compression ratio of this set up going to be.... B18A1 block and crank, B18C1 (GSR) head, OEM LS headgasket, with eagle H-beams, and 81mm GSR 9:1 CP pistons. Let me know. Thanks
I dont really know the pistons specs, nor compression height, but counting the same comp. height as stock; using ls crank will yield about .15 more compression
Nextelbuddy
May 9, 2005 07:42 PM
