what valve cover will fit?
When did the crankcase vent move? Earlier B18B1 have a vent box attached to the back of the block, under the intake manifold. Later B18B1 have both the PCV and the vent on the valve cover. (I don't know what year it changed?)
If your '96 has no vent box on the block, you're stuck with using a newer valve cover. Because you need one that has a place for the PCV valve.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">When did the crankcase vent move? Earlier B18B1 have a vent box attached to the back of the block, under the intake manifold. Later B18B1 have both the PCV and the vent on the valve cover. (I don't know what year it changed?)
Forgot about this. Good call.
