what to use b16 manifold gasket?
I went to Autozone and checked some numbers...the gaskets are all different order numbers, are you definatly sure all of thos will fit? They are all different prices too, do you have a favorite? Im double checking becuase I really don't wanta end up with a gasket thats usesless.
what bout the exhaust gasket?
much thanks
much thanks
Yes, I am sure. that coolant passages thing is BS. Dono what he was talking about.
As far as exhaust gasket goes, any 90+ integra, 99-00 civic si, 94-97 del sol vtec
96-98 CRV, all the same.
sgT check out the first Gen B16 head and look at the 2000 Si. First gen **** has a coolant passage for the FITV built on to the return line that connects to the thermostat housing... If you don't believe me then go check urself...
I may be wrong but I believe the earlier model gakets have a square coolant passage while the newer has a circle coolant passage. Any 90-up b-series exhaust gasket will be work.
trianglegreg
Jan 10, 2006 01:29 PM
