what transmissions are compatible?
Old Jul 14, 2005 | 03:13 PM
masonsjax's Avatar
Default what transmissions are compatible?
i have a 95 civic dx with a b16a, and the tranny, axles/half shaft are from a 96 integra. a collision with a deer by the previous owner left a broken bearing on the driver's side of the transmission. i cant seem to get the partially shattered outer race out, and its leaking oil.
i didnt notice it soon enough, and 3rd gear has started to grind badly, and wont engage sometimes and 5th slips out occassionally too.
i would like to know exactly what options i have. what transmissions fit with these axles, and where's the best (cheapest) place to get one? also, how easy is it to install an LSD kit?
thanks,
--Jason
Old Jul 15, 2005 | 07:11 AM
msmotorsports's Avatar
Default Re: what transmissions are compatible? (masonsjax)
Contact gearspeed. They will tell you exactly whats compatible and what you'll need to fix your tranny. Sounds like just a synchro to me. LSD's are relatively easy to install. You just need to know the proper procedure. There a few posts on here that guide you step by step for B series tranny rebuilds.
Old Jul 19, 2005 | 05:42 AM
masonsjax's Avatar
Default Re: what transmissions are compatible? (msmotorsports)
turns out there is no bearing, so there is no shattered race. it was a piece of the inner housing that was shatterred. the groove that i thought bearings would ride along, is where the little C-clip from the shaft snaps in. i need a new tranny
my speedshop has it on a lift as we speak, hopefully it wont hurt my wallet too much.
if i top off the oil, it shifts smooth as ever, so i'll probably use the internals to build a lsd with a new housing and swap that in later.
thanks for the info.
--Jason
Old Sep 26, 2006 | 08:47 AM
masonsjax's Avatar
to follow up, the transmission only needed a differential. that was the peice that was cracked. the speed shop rebuilt it, but i ended up swapping in a new Integra LS trans just to be sure. thanks to all that replied.
btw, the wife and i just bought a house, so my fun car is for sale
please buy it, i badly need the cash. you know you want to.. asking $7000 OBO.
full details in my post here: http://hondamarketplace.com/zerothread?id=1750943
--Jason
Transmission & Drivetrain
20
Oct 20, 2014 04:45 AM
Tippyman
May 27, 2008 07:46 PM
civicb16eg
Feb 2, 2007 07:29 AM
mgags7
Nov 18, 2005 08:54 PM
gsrHB
Sep 20, 2005 07:50 PM
