What is resleeving?
Old Jun 17, 2003 | 06:14 PM
Mostec_EG's Avatar
Default What is resleeving?
What does it mean by resleeving and how does it improve the perfomance of the engine?
Old Jun 17, 2003 | 06:53 PM
Spudddy's Avatar
resleeving.. basicly your just putting in new cylender walls, and they are stronger than stock. most people do this if they are building their engines to handle more boost. the new sleeves are stronger so more of a BANG can go on inside.
and why don't people take the time to answer simple things like this instead of harking on SEARCH its simple enough to answer fast.. lazy people i swear
Old Jun 17, 2003 | 08:50 PM
Muckman's Avatar
Moderator in Chief
Default Re: (Spudddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spudddy &raquo;</TD></TR><TR><TD CLASS="quote">and why don't people take the time to answer simple things like this instead of harking on SEARCH its simple enough to answer fast.. lazy </TD></TR></TABLE>
Because most ppl on here are ******! hah
Old Jun 18, 2003 | 06:07 AM
Wes V's Avatar
Default Re: (Muckman)
In regards to the question about it helping horsepower; re-sleeving doesn't increase horsepower in it's self. This is with the assumption that you go with the same bore.
However, if you are having the work done (to all four cylinders), then it opens up the possibility to go to a bigger bore and that would make a difference.
Wes
Old Jun 18, 2003 | 11:54 AM
granada_sun's Avatar
so basically if you are going to increase bore size you'd want to resleeve the engine......
Old Jun 18, 2003 | 01:23 PM
Wes V's Avatar
Default Re: (granada_sun)
The amount that you can bore an engine varies from engine type to engine type. If you were doing a major bore, then you would most likely have to sleeve it.
Wes
Old Jun 22, 2003 | 10:35 AM
caliguy1313
Guest
Posts: n/a
On a real motor (not a honda motor) you would not want to sleeve youre whole block. A sleeve leaves no deck support. The cylinder walls are what support youre deck and if you sleave a block you turn those cast walls into press fit walls, which if you are really making lots of power is very bad. but i guess honda guys dont have to worry about problems like making a lot of power.
red beast
21
Apr 11, 2007 08:46 PM
rayman009
Audio / Security / Video
12
May 18, 2004 02:15 AM
1hotcivicSi
25
Feb 29, 2004 11:57 PM
Turboteggy
Jan 29, 2004 06:44 PM
civicnightmare
Jan 22, 2004 03:09 PM
