What is the gold colored coolant hose on the back of the block??
What make model and trim of car?
Pictures help. I can't think of any hose on an older Honda that is gold. Maybe it's a third party part?
Picture please.
Impossible to identify a hose out of all the hoses in the engine bay off your description.
Hell, for all we know, this aint even a Honda we're talkin' about.
I think you may be referring to the water pipe on the back of the block, it is kind of a bronze gold color when it isn't rusty. See item 9 on the attached picture. Goes between the thermostat housing and water pump, honda list it as pipe, connecting.
Part # 19505-P2A-000 (for the vehicle you listed).
This is what I'm guessing he's referring to also.
I've never seen a non corroded one.
Also would like to thank you for pointing out that OP did provide the car information. I scrolled to the first post so missed the addition in a later post.
My apologies OP.
Based on the fact your pipe is still in near pristine condition, if you are having a leaking issue with this pipe, it's likely either the seals on the ends or much worse, a cracked block.
Your car is not the year range known for the problem of the block cracking (2006-2009) so not sure why you would be experiencing a problem with this pipe.
krysted9354
Jan 27, 2009 03:34 PM
immrtaltchnq
Aug 28, 2006 10:06 AM
