What could be causing my radiator to break?
Old Aug 18, 2002 | 09:32 PM
TenaciousC's Avatar
Default What could be causing my radiator to break?
Happened a few times now,once with the stock radiator and then again with a cheap aftermarket one. Im doing a compression check tomorow, but i dont think its the head gasket. Could a bad thermostat have anything to do with it? i cant think of anything else that would affect it.
btw i have a turbo ls
Old Aug 18, 2002 | 10:37 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: What could be causing my radiator to break? (TenaciousC)
It's usually caused by a bad headgasket. Even a small pinhole can increase the pressure beyond the factory limits.
You may want to consider a good radiator, like PWR, or Fluidyne.
Old Aug 18, 2002 | 11:08 PM
Ri5e's Avatar
Default Re: What could be causing my radiator to break? (B18C-EJ1)
Definetly get an aftermarket one. The stock ones just plain suck because the ends are made out of plastic.
Old Aug 19, 2002 | 07:20 AM
X2BOARD's Avatar
Default Re: What could be causing my radiator to break? (BG Boost)
Old Aug 19, 2002 | 10:09 AM
88_SC_CRX_Si's Avatar
New User
Are you sure that the rad hose clamp, is clearing the hood when it shuts?
[Modified by 88_SC_CRX_Si, 11:10 AM 8/19/2002]
Old Aug 19, 2002 | 10:38 AM
fuguman's Avatar
New User
how can i tell wether my headgasket is ok or not?
Old Aug 19, 2002 | 12:33 PM
Turbo Powa's Avatar
Default Re: What could be causing my radiator to break? (fuguman)
compression test
Old Aug 28, 2002 | 09:25 PM
Quetzolcotl's Avatar
Default Re: What could be causing my radiator to break? (Civic LX 29)
this just happened on my girl's gsr. the fan relay had went out so the fans were not running. it also was prettly low on coolent and overheated once. the radiator blew. replaced it and got the fans working. it seems fine now.
slowboy90
Apr 8, 2012 02:18 PM
mikep_95133
May 10, 2009 03:14 PM
TenaciousC
Aug 20, 2002 10:18 PM
yoshe95si
Dec 25, 2001 05:22 PM
