What compression ratio?
Old Sep 25, 2002 | 06:24 PM
McFly's Avatar
Default What compression ratio?
I am about to order my postons and rods. The set up is a B16 block and a GSR head and intake. I have the GSR PCM so the 2 stage manifold will be functional. I plan to run a direct port NOS system but I don't know what compression ratio I need to run. I want to run at least a 100hp shot or more, possibly 150 or 200. What CR is suggested? Thanks
Old Sep 25, 2002 | 07:37 PM
Kataku2K3's Avatar
Default Re: What compression ratio? (UnderFire)
I would suggest something around 10.0-10.5:1 with forged pistons.. Your compression with stock B16 bottom end and GSR head will be around 10.4:1 just like a Jspec 5 million series motor unless you already have a 5 mill. block to begin with.. Look into JE pistons and Eagle rods cuz they are both fairly inexpensive.
Old Sep 27, 2002 | 02:08 PM
McFly's Avatar
Default Re: What compression ratio? (JDMspecEG6)
Thanks
.adam.
Mar 2, 2007 03:39 PM
Nextelbuddy
May 9, 2005 07:42 PM
lavo81
May 8, 2005 03:48 PM
Nextelbuddy
10
Oct 8, 2003 05:47 PM
McFly
Sep 27, 2002 07:10 PM
