What alternative MTF can I use
Old Jan 4, 2003 | 04:52 AM
qwklude82's Avatar
Default What alternative MTF can I use
Some of you guys have read my other topic about the manual transmission fluid leaking out of my car. I was wondering what alternative I can use since Honda service/parts is closed today and I can't pick up any MTF from there. My friend said they have some additives in their fluid that make it better to use but I was thinking that there's gotta be something else I can use that is just as good. Is there?
Thanks
Old Jan 4, 2003 | 05:03 AM
b19coupe's Avatar
Default Re: What alternative MTF can I use (qwklude82)
You can use 10/40 motor oil and it will be fine, but as soon as you can change it to MTF. MTF = improved shift quality and longer synchro life.
Old Jan 4, 2003 | 05:10 AM
qwklude82's Avatar
Default Re: What alternative MTF can I use (b19coupe)
ok thanks
Old Jan 4, 2003 | 05:20 AM
qwklude82's Avatar
I have a little bit of Honda MTF left and was wondering if it is bad to mix the Honda MTF with the 10W-40 oil.
Old Jan 4, 2003 | 05:50 AM
b19coupe's Avatar
No problem mixing the two that I am aware of.
Old Jan 4, 2003 | 06:21 AM
qwklude82's Avatar
ok i finished pushing the axle in...dang that thing moved a good few cm more. No wonder it was leaking fluid.
Old Jan 4, 2003 | 06:23 AM
qwklude82's Avatar
I just read up on Redline transmission fluid. I can use that instead right? Any problems mixing with Honda MTF again ??
Old Jan 4, 2003 | 06:32 AM
Shawn C's Avatar
In The Garage
try im'ing BlackDeuceCoupe. hes real smart about that **** and i think he totally recommends something like NEO oil for it. Im not crazy about Honda MTF myself, and it takes a lot for me to say that. Im a freak about oem honda. also, be careful about using other tranny fluid, because just about every manufacurer uses a different fluid for manual trannies (ford uses atf, honda uses 10-30 oil or honds MTF, nissan uses GL-4 75-90 gear fluid, just to name a few) so be extremely careful just buyin "manual transmission fluid", because its probably not ~10w30 oil.
[Modified by 22lbGS-R, 3:35 PM 1/4/2003]
Old Jan 4, 2003 | 08:08 AM
integra6650's Avatar
Default Re: What alternative MTF can I use (22lbGS-R)
use redline mtf
Old Jan 4, 2003 | 11:26 AM
Kidnkorner's Avatar
i work in a honda acura service garage, it all depends what year is the transmision. most older transmisions call for plain old motor oil, unless a honda service manual, or tech specifically states to use MTF, use 10w30. its a pain in the *** to fill without a lift. if you want to go the synthetic route, use castrol, or mobil 1, and if you really can afford it use redline. remember to change the fluid every 15000 miles.
bowlofrice
Honda Civic (2001 - 2005)
Jun 17, 2007 03:58 PM
kevotron
Jan 16, 2005 03:45 PM
Buckshot
Apr 5, 2003 11:20 AM
FullMetalJacket
15
Mar 23, 2003 08:13 AM
KooK
Jul 29, 2002 03:06 AM
