Weird Clicking chatter noise when turning.
Old Oct 23, 2015 | 06:51 PM
n*werk's Avatar
Default Weird Clicking chatter noise when turning.
So recently i notice a nasty chatter/clicking noise when i pull in my parking lot or even going to the drive thru the car will Chatter when turning left or right. The weird thing is when the vehicle is cold or if i drive short distance, its fine (no chatter/clicking when turning). It only happen when i drive like 30 miles plus or can i say when the car warms up? Never had this problem so I'm stump as of now on what it can be, so any suggestion would be appreciated. Thanks
Specs: 98 civic cx
h2b swap
Itr Lsd transmission
Dss level 0 axle (brand new)
5 Lug conversion 36mm axle
Jic Magic coilover shocks
Things i have tried: Replace axle, Jacked up the car to check wheel bearing is bad, inspected the tires and wheel, had wheel alignment redone, Transmission has Honda MTF, might be missing some other stuff i tried but just post and i let you know.
Old Oct 24, 2015 | 12:22 PM
oneheadlight's Avatar
Default Re: Weird Clicking chatter noise when turning.
check your cv joints, might not be enough grease inside there. once you begin moving more the grease gets distributed and you don't hear the noise.. just something to check..
Old Oct 24, 2015 | 06:15 PM
n*werk's Avatar
thanks for the reply, what do you mean by grease inside there?
Old Oct 24, 2015 | 07:09 PM
there is grease packed into the cv joint, the rubber boot over it keeps the grease inside so it doesn't fling/thrown out. Plus the boot keeps the cv joint clean from dirt/contamination. I'm wondering if the grease inside the cv joint, that there is not enough, you begin to use it, it the distributes the little grease it has, noise stops. That's what I meant. It was a thought and something to look into since it might be the problem.
Old Oct 24, 2015 | 07:29 PM
holmesnmanny's Avatar
I've seen parts store axles that had no axle grease added inside that went bad and making noise in a tiny amount of miles.
Even oem axles will have their grease wear out after many miles. The grease does get old and stops protecting, even if there is no leak where foreign particles can get inside.
Old Oct 24, 2015 | 08:24 PM
n*werk's Avatar
well, I purchased a brand new set of axle from DriveShaftShop and i am sure there enough grease inside the boot. But the problem happen with my old axle and my new axle from Dss.
dc2doi
Oct 15, 2007 11:23 AM
whp
Feb 3, 2007 08:08 AM
D16Z6_turbo
19
Mar 17, 2005 11:37 AM
Stellar1
25
Mar 11, 2003 05:35 PM
REDBARON
14
May 24, 2001 07:25 PM
