Weird brake problem (VTi Civic)
Old Apr 23, 2007 | 01:07 AM
Gaz's Avatar
Gaz
Default Weird brake problem (VTi Civic)
Quick query for you Honda experts ....... I'm in the UK and have a 1998 VTi Civic hatch (equivalent of your JDM SiR).
It keeps failing our MOT test over here showing not enough pressure to the rear passenger side brake under foot braking. The front brakes and handbrake are totally fine.
so far I've :
1) Changed rear caliper
2) Changed pads
3) Changed fluid and bled system
4) Changed flexi-hose to passenger rear caliper
..... and no difference.
Any more ideas?
Gaz
Old Apr 23, 2007 | 12:41 PM
vpower101's Avatar
check your porportioning valve to your pass side brake
Old Apr 24, 2007 | 02:17 AM
Gaz's Avatar
Gaz
Default Re: (vpower101)
Where is this valve, near the master cylinder in the engine or actually near the rear of the car?
Gaz
Old Apr 24, 2007 | 09:08 AM
slomofo's Avatar
GDD Member
It's in the engine bay.
Follow the hard brake lines from the master cylinder and they go into the proportioning valve.
Greyknight1138
Suspension & Brakes
Apr 7, 2014 07:32 AM
mtownsi
Mar 18, 2010 06:37 PM
douglaslovin
Nov 26, 2009 11:41 AM
Touch
Oct 29, 2006 06:56 AM
FourthGenHatch
Jul 31, 2003 06:53 AM
