Water Temp Sensor Placement?
I'm going to install my Auto Meter water temp gauge, but wondering where I should put the sensor. I have a hose adapter that goes on the radiator hose and the temp sensor screws in.
Should I put it coming from the upper or lower hose?
Not too close to the head though. This hose adaptor will vibrate a little so you want the flexable hose to soak up some of that vibration without tearing the hose over time, cyclic vibration. Use some teflon tape around the sensor threads, I personally use some RTV on the hose adaptor to hose attach areas.
That is where I put it, half way between the radiator and head in the upper hose. No leaks and I'm getting a perfect reading from 200-210 beating the **** out of it during the day
zx92027xz
19
Jan 15, 2014 04:36 AM
asiansgoweeee
Nov 3, 2004 08:03 AM
