water temp gauge install on a d16y8 HELP NEEDED!!
Old Jul 1, 2004 | 06:05 PM
honda67's Avatar
Default water temp gauge install on a d16y8 HELP NEEDED!!
I just bought my gauges and and i have a problem with the water temp gauge.I think i no where to put it but want to make sure.
Old Jul 1, 2004 | 09:54 PM
Crazydave's Avatar
Default Re: water temp gauge install on a d16y8 HELP NEEDED!! (honda67)
whats wrong with the one on your gauge cluster?
Or is your gauge cluster not working.
it goes above your stearing wheel
explain your problem better
Old Jul 2, 2004 | 07:10 PM
honda67's Avatar
Default Re: water temp gauge install on a d16y8 HELP NEEDED!! (Crazydave)
i have a after market gauge on the a-piller and i want to hook it up.It has a like a brass fitting at the end.
Old Jul 2, 2004 | 09:31 PM
senpai's Avatar
Sounds like it's mechanical. That means you need to put the sensor where coolant flows.
Old Jul 5, 2004 | 06:39 AM
civic-4-ges's Avatar
Default Re: water temp gauge install on a d16y8 HELP NEEDED!! (maztur)
Many people put the fitting on the un-used tapped spot on the waterneck. Its a long wire to route, but its a good spot.
Old Jul 20, 2004 | 10:37 PM
kaoticimports's Avatar
the fitting that come with the guages want fit on any places that i found.thats includes the air bleeder valve,the two under the distributor,and the on the back of the head where the coolant flows bak to the radiator.is there any other places that could be tapped.
streetcartuner
Jan 12, 2008 09:59 AM
boostincoupe
Aug 12, 2004 05:36 PM
honda67
Jul 1, 2004 06:01 PM
