vvvvrrrroooooommmmmm BANG!
Old Oct 23, 2004 | 09:51 PM
W.O.P.'s Avatar
Default vvvvrrrroooooommmmmm BANG!
if you read the integra fourm you know this is kinda repost, but i didnt get any answers
this is what happened going uphill with what i thought was a 1/4 tank of gas but it was actually low. messed up anything? filled up the tank and it seems ok now. any thoughts?
well heres the codes i threw after this incident
P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction
P1366 Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) Intermittent Interruption
and P1367 Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) No Signal
ok heres the problem though. my book says its the crankshaft. not the camshaft. so swap out these words. the ones i put up were the H-T explaniations. so whos right? and is my car fucked? it drives fine....for now
Old Oct 23, 2004 | 10:33 PM
W.O.P.'s Avatar
Default Re: vvvvrrrroooooommmmmm BANG! (1quickLS)
jesus tittyfucking christ will someone answer me?
Old Oct 24, 2004 | 06:56 AM
W.O.P.'s Avatar
thanks guys u have been alot of ******* help
Old Oct 24, 2004 | 07:33 AM
mmuller's Avatar
Mad Scientist
dude...calm your horses
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1quickLS &raquo;</TD></TR><TR><TD CLASS="quote">
nobody can aswer you cause your question makes no sense....
what is tis supposed to mean? what you run out of gas? the car blew up? gas was just low?
explain yourself better.
IF your saying your carr runs normal, i would clear the codes out of the ecu to see if they come back first
Old Oct 24, 2004 | 10:27 AM
civicgsr19's Avatar
Either your car backfired, or you sucked a skunk up your cold air intake.
Clear the code see if they come back.
Old Oct 24, 2004 | 03:09 PM
W.O.P.'s Avatar
Default Re: vvvvrrrroooooommmmmm BANG! (civicgsr19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr19 &raquo;</TD></TR><TR><TD CLASS="quote">Either your car backfired, or you sucked a skunk up your cold air intake.
Clear the code see if they come back.</TD></TR></TABLE> ummmm ok?
Old Oct 24, 2004 | 06:36 PM
W.O.P.'s Avatar
p1337 crankshaft position sensor"B" fault (no signal) IS THIS BAD?????????
Old Oct 24, 2004 | 07:41 PM
Discosteak's Avatar
you need a distributor and an o2 sensor. go buy them NOW
Old Oct 24, 2004 | 07:43 PM
Discosteak's Avatar
Default Re: vvvvrrrroooooommmmmm BANG! (BADEG6)
the dizzy is what is causing all three of your non 02 related codes. you probably have a bad bearing in your distributor. and I pmed you H-t doesnt get more helpful than that short of buying the parts and throwing them on for you
Old Oct 24, 2004 | 08:53 PM
civicgsr19's Avatar
ummmm yea.
Is the replace user light on?
Old Oct 24, 2004 | 11:14 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1quickLS &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys u have been alot of ******* help </TD></TR></TABLE>
well why dont you give us more of a ******* description. vroom bang dosent mean ****. tell us EXACTALLY WHAT HAPPENED and what you have done to try to fix it. it would also help if you told us the car, the year, the engine, etc.
dont get mad because you left out vital parts of information.
Old Oct 25, 2004 | 11:03 AM
Death_to_Thieves's Avatar
Default Re: vvvvrrrroooooommmmmm BANG! (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
My thoughts exactly
Old Oct 27, 2004 | 08:11 PM
not so JDM Dan's Avatar
Default Re: vvvvrrrroooooommmmmm BANG! (8000KReV)
Is the replace user light on?[/QUOTE]
Old Oct 27, 2004 | 08:16 PM
Nate047's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr19 &raquo;</TD></TR><TR><TD CLASS="quote">ummmm yea.
Is the replace user light on?</TD></TR></TABLE>
LOL.
airikkCRX
May 15, 2010 06:47 PM
TurboEM1
Jun 16, 2005 02:22 PM
