vtec activation?
Old Apr 24, 2003 | 02:50 PM
untitled's Avatar
Default vtec activation?
b16a in 91 teg. still obd0. want to know if there is a way to activate vtec without buying pr3 ecu? if so, how would i wire vtec pressure, ground, etc....? also are the spark curves in the b18a ecu good for the b16a?
Old Apr 24, 2003 | 03:58 PM
customx_'s Avatar
New User
Default Re: vtec activation? (88crx91integra)
without the a correct ecu, its gonna be hard to retain correct fuel maps for your motor. you can always convert to obd1 and run a chipped p28, more cheaper than pr3/pw0
Old Apr 25, 2003 | 07:35 AM
untitled's Avatar
Default Re: vtec activation? (f0rk'd)
how is it more cheaper? i have a setup obd0 right now. all i would need is ecu. with obd1 wouldnt i have to buy a conversion harness, dizzy injectors and a 4-wire 02sensor, not to mention buying the ecu.
Old Apr 25, 2003 | 09:53 AM
HRTuning's Avatar
How soon are you planning on going turbo? A PR3 or PW0 might be in your best interest if it's soon... If not, How exactly do you want to activate vtec? I might be able to help you out... the most ghetto way I've ever seen vtec wired up is by putting it on switch taped to the shift ****... lol... I can help you out with the ecu reprogramming too... which ECU are you using?
MarioDb8
Jul 29, 2013 08:53 AM
TMC_EF
15
Aug 16, 2008 06:31 AM
DOHC-V-TEC-DA
Feb 3, 2006 06:03 PM
