Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Vss location b18? (https://honda-tech.com/forums/tech-misc-15/vss-location-b18-3203968/)
EgLuv94 Apr 18, 2014 05:33 PM
Vss location b18?
I have 94 eg with a b18b1 swap Ls tranny. My speedo works half the time, but its either at the correct speed or at zero. From what i think its the vss but i dont know where its located to replace it. Any help would be great.
Black93Lude Apr 19, 2014 06:25 AM
Re: Vss location b18?
It'll be in the transmission, near the output shaft.
An intermediate reading could be anything, Obviously, check the obviousness. Looseness, frayed harness, shit like that. If everything appears to be good at first glance you can either throw parts at it or have it tested.
EgLuv94 Apr 19, 2014 01:58 PM
Would changing the cluster help? And so your saying the vss is inside the tranny? So i would have to pull the tranny to get to it right?
mechanix619 Apr 19, 2014 04:14 PM
The VSS is technically inside the transmission but the transmission doesn't have to be removed in order the change it.
It's should be pretty easy to find. It's next to the output shaft and has a wire harness connected to it.
EgLuv94 Apr 20, 2014 07:11 PM
When i looked the part up it had a gear on the end of it. Does this mean i will have to line up the gear slpines on the new part to the ones inside the tranny? I found where tge vss is i just dont know how hard it will be to replace.
mechanix619 Apr 20, 2014 08:07 PM
It's easy to replace. The gear will have to be aligned but it's not hard.
