VALVE SPRINGS?
Just got my stage 2 crane cam from jegs.. is it completely neccessary for new stock valve springs.. crane cam recomends it.. Honda dealership wants 189$ for new ones... is that a good price or no, cuz i cant find em any place else. Napa only has the exhaust side..and they are 15 a piece...any one have experience in this..lemme no asap. thanx.. oh and i have only 60k on my motor...sohc zc
It's recommended because they don't know the condition of your stock springs and they don't want you to get valve float in the high rpm's due to faulty valve springs, then have you turn around and blame it on them. Check e-bay for some aftermarket performance springs.
The sohc zc pretty much has the same cylinder head as the d16a6. I run a Gude Gorilla cam--which is probably the second most wicked shelf cam available for this motor, its power band is about from 5800-8500 rpm--and with new stock springs and retainers--routinely shift at 8500-8600 rpm...the only aftermarket valve springs I have found for a d16a6 are the Iskys. Sohc can get away with using a stock spring, because the valves are so small and light. Sohc-vtecs can apparently withstand 9000-9200 using stock valves, springs, and retainers--the key is having NEW factory springs--valvesprings lose their tension after a while. Still, for extra insurance it can't hurt to get some Isky springs--as I am eventually going to get. You don't want or need the ti. retainers on an sohc though...
Once (by accident of course) I have spun this motor (for like 2-3 seconds) to 9800-10,000 rpm...gods honest truth, with no harm done!! I would NEVER intentinally do something like that though...
I once had a D15B8, ported PM6 head with bullfrog cam, 98 EX transmission, and a chipped P75, I ran 10krpm for about three days no problem.... I later found four exhaust vavle stems poking out of my catalytic converter while the valve faces were upside down and planted in the head. I'm sure there are hundreds of others out there who had fun blowing their stock motors during the days before their swaps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo »</TD></TR><TR><TD CLASS="quote">I once had a D15B8, ported PM6 head with bullfrog cam, 98 EX transmission, and a chipped P75, I ran 10krpm for about three days no problem.... I later found four exhaust vavle stems poking out of my catalytic converter while the valve faces were upside down and planted in the head. I'm sure there are hundreds of others out there who had fun blowing their stock motors during the days before their swaps.</TD></TR></TABLE>HA..damn.. thats crazy... i went ahead and ordered the new stock springs from Honda dealer. set me back 190...but thats not too bad..ill let u no how it goes after the install
